Question about Honda Mmd 5000 Watt Generator W/ Engine Ngk 6000H
My ngk 7000h will not stay running without the choke staying open. any clue on what to do
4 Suggested Answers
  • 8 Answers
SOURCE: bike will start with choke on, but will not stay
clean carbs
Posted on Apr 05, 2009
  • 330 Answers
SOURCE: Ok hope you can help, 01 stall's out after a few
Fuel system may need cleaning, trash in the carbs will sometimes let it idle then bogg or blubber when throtled up especialy under a load.(also makes starting a chore).
Posted on Apr 07, 2010
Testimonial: "I cleaned the carbs out and emptyed the gas tank filled with new gas and added sea fome. Did a few more things and seems to be running fine. Took it for a run got her up to 80 and ran her for about a 1/2 hour just around the city. We will see if it stays. I still think my spark wires may be bad. Thanks for the help"
heimlich
  • 1978 Answers
SOURCE: MY HONDA A.C.E WONT STAY RUNNING WITHOUT THE CHOKE
You need to take the carburetors off the machine and open them up. Pull the jets out, make sure they are clear and you can see through them. Squirt carburetor cleaner through the passageways in the carburetor body and blow the passageways out. That is where the carburetor dirt is hiding. Use genuine Honda carburetor cleaner . Gumout is too harsh for Keihin carbs. If you want to try to clean the carburetors without disassembly buy some Chevron Techron and pour it directly into the bowls. Let it sit over night. Drain your gas tank and follow the directions on the bottle to mix 1 gallon of gasoline in a shock treatment. Pour the shock treatment in the tank , start the bike, slowly take the choke off, and run it till it idles on it's own (usually 5-10 minutes). Be careful not to let the pipes get too hot or they may blue. Then take it for a 5-10 mile drive and fill the gas tank. If the carburetors are not too bad this should clean them up. Other wise you will have to take them apart to clean them properly.
Posted on Mar 24, 2011
Mower won't stay run
If your machine only runs on choke then you need your carb cleaned or replaced
Aug 04, 2014 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
My hmc green machine 3000ss weed wacker carb needs adjusting it only runs with choke closed
Try cleaning or changing the air filter. If it dirty the engine will not stay running with out the choke on.
Feb 17, 2014 | 2010 Vuka XL 125
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 | Garden
Ok hope you can help, 01 stall's out after a few min. starts good and stay runing most of the time but yesterday I killed the battery due to it not staying started, took it out and recharged it today. Now...
Apr 06, 2010 | 2001 Honda VT 750 DC Shadow Spirit
Cant get a yamaha ttr 125 to start
I'm having a hard time keeping the engine to idle without the choke to stay on position. When the choke is off, engine would shut off.
any clue?
Mar 20, 2010 | 2004 Yamaha TT-R 125 L
1993 blaster wont stay running
try cleaning carb and see if the choke is hung up also make sure it has the right plug ngk b8es
Feb 22, 2009 | 2003 Yamaha YZ 250
Exaust change
colder plug for NGK. Should I stay with that plug or go with a hotter plug ? That's really ... weird. You have to use the choke ... which indicates you went lean The old exhaust needed no choke shich indicates rich... But you went back to stock which should, by normal standards, make the bike run RICHER if the jet sizes were increased,,,
Nov 10, 2008 | 2008 Benelli Tre-K 1130 Amazonas
Honda Mmd 5000 Watt Generator W/  Engine Ngk 6000H Logo
37 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
