Question about Cameras
I have a Pentax IQZZoom70 camera and need a manual as the original was lost. can I still get one
Has am AF macho lens attached to camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You may download the manual here.
Posted on Dec 12, 2012
jackboy
  • 2985 Answers
SOURCE: Pentax Ist DL auto focus not working anymore after using Quantaray AF LD 70-300MM Lens
It seems to be a connection issue between the Lens and the Camera body. Perhaps the mount is not true to the body Ask Pentax about this their Technical Support Team
Posted on Jul 07, 2007
  • 6 Answers
SOURCE: "Lens not attached" warning when lens is in fact attached.
Hello. Check the area around the lens mount carefully - specifically the contacts. Make sure all are clean and protruding the same. If one is lower than the rest, try 'flicking' it with a fingernail (lightly) to see if it will pop up to the height of the others. It may have dirt or a particle of dust lodged. If this doesn't help, get the lens to Nikon for a check-up.
Posted on Jun 06, 2008
dlundmark
  • 797 Answers
SOURCE: Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
Posted on Jul 19, 2008
E-man_1
  • 56 Answers
SOURCE: Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Posted on Sep 10, 2008
SOURCE: AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Posted on Mar 04, 2009
Hi There! I do hope someone can help. I dropped
You don't need a user's manual, you need a service manual that gives details on taking apart the lens. I know of no source for such an old lens. Here a few links that may help:
http://ricehigh.blogspot.com/2011/01/disassemble-old-takumar-f-28-80-zoom.html
http://members.shaw.ca/hargravep/70-210.htm
However, with one of these lenses going for $20-$30 on eBay, I don't think it's worth a day's time to take one apart and put it back together.
Hope that helps,
Bax
Aug 18, 2013 | Photography
Purchased an eos50e with tamron lens 28-200mm a few years ago, can the lens be used with a digital camera
its not possible to use the lens with digital camera .........but can you be more specific about the digital camera with which you are trying to use the lens
Aug 07, 2008 | Canon Cameras
I would like to use my Sigma 600 Mirror lense on Nikon M80 digital camara body lense was used on a Pentax Super A camara before can it fit
Sorry, no. If it fit onto a Pentax camera then the lens has a Pentax mount. The Nikon (I assume you mean the D80 digital camera, or perhaps the N80 film camera) has a Nikon mount. Since the Nikon mount has a deeper flange distance than the Pentax mount, there are no adapters available to allow you to fit a Pentax-mount lens onto a Nikon camera.
Jan 14, 2013 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Hi, i have a pentax ISTDL and when i try 2 use it in manual focus the AF still works on its own
Check your lens there is often a AF/MF auto/manual focus switch
Other than that it could be a problem with the camera take it to your dealer
Apr 08, 2011 | Pentax *ist DL (W/18-55 LENS) Digital...
Are there any digital cameras on the market that will allow me to make use of my existing ricoh k mount 35 mm camera lenses? (originally used on a Ricoh KR10
Some pentax digitals(most) will accept k mount lenses. Ricoh differed from the Pentax standard in one slight -- but important -- way. They used a locking pin (called the "Ricoh pin") that just happens to fall at exactly the same place as the auto-focus socket on Pentax auto-focus cameras. (That include Pentax film and digital SLRs with auto focus.) If you put your Ricoh lens on the AF Pentax, you may find that the Ricoh pin will get stuck in the AF hole and you can't get them back apart. The fix is simple, if you are even a little bit handy and have a jewellers' screwdriver. You can remove the pin from the Ricoh lens, and then safely use it on your Pentax cameras. The lack of a pin doesn't seem to adversely affect either the lens or the camera.
For more details, see here:
http://forums.dpreview.com/forums/read.asp?forum=1036&message=19214685
Nov 04, 2010 | Photography
Sigma 70-300mm lens defaults to manual focus
It will default to manual through the viewing screen. It will only work on automatic, using the viewfinder. Make sure you also set the focal length (lens to shutter distance). You might also have a mf / af switch on the lens. This also only works through the viewfinder.
Jan 16, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Jul 05, 2007 | Pentax *ist DL (W/18-55 LENS) Digital...
Will this lense fit on my camera?
You can have the 28-300 temron lens with beynout mount of pentax it will deffinaitly works like another lens manually , because af lens has a option of manual also so it will be suitable
Oct 01, 2006 | Tamron AF28-300mm XR Ultra Zoom for Pentax...
Cameras Logo
29 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
