Question about Toshiba Qosmio Computers & Internet
Qosmio F10 When booting receive a blue screen, then replaced hard drive, recovered the operating system etc using supplied CD. Whne fininshed repartioning says to remove and pressa ny key which I do. The laptop reboots, but almost immediately comes up with blue screen again.....grrr It is an older machine, but has a beautiful display on it for watching movies, so wondering if it is worth fixing the MB or if a controller on the MB can be replaced?
  • 1,591 Answers
Try replacing the RAM, or pulling half of it if it has 2 sticks. Try each stick on it's own. If that works, replace the bad RAM stick, or replace both sticks. If it only has one stick of RAM, see if you can borrow a stick from a local shop. Take your RAM in so they can match the size, speed and voltage. Other shops may offer to let you buy a stick, and refund you if it doesn't solve your problem.
Posted on Dec 12, 2012
  • Ian Newman Feb 10, 2013
    Thanks, tried this still getting blue screen. Will send to Toshiba to quote on repair.
KatFishGR
  • 90 Answers
SOURCE: Laptop receiving message: No operating system found
That error usually indicates one of two things, your file system is corrupt and the master boot record or partition tables have corrupted.... or, in light of a liquid being spilled, some possibly got into the laptop.
I'm not sure right off the top of my head, but I think the hard drive has an access door on the bottom. Which you can remove a couple screws to remove the cover. I would visually inspect under that cover, and other covers if any while your at it, to check for any signs that liquid got in it.
Posted on Oct 23, 2007
  • 236 Answers
SOURCE: Compaq Presario R3000 not booting up
set the bios/cmos to boot first of your CD drive. get your support discs and restore to original. your hard drive OS has failed and needs to be re-installed. the problem maybe is that when you do that option you will get all your data erased. your solution to that since you can still get the data on the drive when used as external is to back it up. then full restore your system.
if you dont have your restore kit, you can use your Windows OS to fix it, repair option when you boot from CD.
Posted on Apr 02, 2008
marked
  • 6487 Answers
SOURCE: Laptop will not boot up
THis error is telling you that there's a problem with yoru laptop hard driver where the operating system is installed that's why it cannot boot, so the best thing to do here is to replace the hard drive then after that , if you have important file on that old hard drive from your laptop you can buy a hard drive enclosure and make the old hard drive a external drive and that way you should be able to retrive some of your data that is save on it.........
Hope that helps.......
Posted on Sep 27, 2008
SOURCE: "Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Posted on Jul 10, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Toshiba Qosmio laptop with Phoenix securecore
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Posted on Sep 07, 2009
Testimonial: "I'll go out to Toshiba and get a rescue disk. FYI:I booted up with an XP disk to try to load the OS, but keep getting the blue screen"
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
What is load setup default
So you reinstalled the operating system ? then returned to set faisafe or optimised defaults
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Oct 24, 2012 | Acer Extensa 5420-5687 Notebook
UNMOUNTABLE BOOT VOLUME ERROR ON GATEWAY GM5045E WITHOUT RECOVERY OR WINDOWS XP DISC.
An unmountable boot volume error suggests that you may have a hard disk failure or at least some corruption to the hard disk which the system uses to boot Windows XP.
To try to resolve this problem you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) then would need to be burnt on to a blank CD then the computer booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need a Windows install CD or other recovery CD media.
If HDAT2 finds a lot of unrecoverable errors then you should seriously consider replacing the drive - you should be able to recover data from the old drive using other tools on the Hiren's Boot CD, including booting the CD mini-XP environment and using the tools there too.
Dec 29, 2011 | Gateway GM5045E (RBGM5045E) PC Desktop
Unmountable boot disk error on blue screen
first, recover your files. You will need to use some data recovery program like asoftech data recovery. you can download it from
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Data-Recovery.shtml
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 07, 2011 | Gateway Computers & Internet
How can I install a new hard drive when I cannot boot from a cd?
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
hope this helps
Jul 29, 2011 | Seagate 80Gb 7200rpm Ultra ATA/100 2MB IDE...
My computer is at e screen, f10 and f2 what should i do
it should exit that screen in a couple seconds then boot into you operating system. (side note; f2 takes you to the BIOS settings page i recommend not tinkering with that and f10 takes you to the boot menu. the boot menu is for choosing which device you want to boot from cd-rom, hard drive, etc.
Mar 31, 2011 | E-Machines eMachines Desktop PC
This is regarding an acer mini laptop wen i turn it on it says: check cable connection ..! PXE-E63: error while initializing the NIC PXE-M0F: exiting intel PXE ROM No bootable device -- insert...
You need reinstall the Operating System.
How do I reinstall my Operating System on my notebook or netbook with recovery disks?
In order to recover the Operating System using Acer Recovery Media please perform the following:
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our online Acer order form..
Oct 28, 2010 | Acer Aspire One PC Notebook
I was just on my ibm t43 and it froze so i manually turned it off now it wont turn back on. it acts like it is going to then it pops up a screen that say an problem has been detected
Hello, Meagan.
Sounds like an operating system problem.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If you can't access System Restore by Safe Mode, try Offline System Restore:
1. Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on System Restore.
6. Choose the date to which you want to restore
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Apr 19, 2010 | IBM ThinkPad R40 2722 Notebook
How do i formatt the hard drive
turn on the computer, immediatly after turing on the computer, keep tapping F10, it will go to boot page, insert the XP cd, then select the DVD/CD ROM, hit enter, then it will start intiating the system recovery, format the HDD, and then follow the screen
Sep 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba Qosmio laptop with Phoenix securecore util,uses SATA drive. Had to replace the Hard drive, HDD1 password issue After installing the new HD and at boot up, blue screen occurs I get errors F78da640,...
Sep 07, 2009 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
