Question about Intellinet Active Networking CAT5e UTP Cable
What is UTP CAT 5e cabel? - Intellinet Active Networking CAT5e UTP Cable
  • 623 Answers
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Posted on Jan 13, 2009
Does the yellow 30v cable coming from the modem connects to my laptop?
To me 30V means 30 volt.. if that's the case, no it doesn't connect to your computer.. If it is, however, this: WennoW 4ft Yellow 26AWG 4P FT1 60 30V UTP ETL Verified CAT 5E TYPE CM LAN...
then yes, it is a network cable or ethernet cable and is meant to plug into your computer or router or switch or hub
Aug 13, 2015 | Computers & Internet
My iPhone won't work.
get a new one and get insurance this time
Mar 04, 2013 | Belkin 33 ft Cat 5e UTP Patch Cable...
If I reset my dynex G router using the reset button; 1) What will be my default password? 2) Will resetting the router affect the hard wired connection?
the default ip is  username admin password admin or leave the password blank.
hardwired you mean is utp cat 5e cable? known as internet cable, which using switch hub.
well, it will affect if the wire/cable you mean is came from the router you reset.
the wire and the access point  came from the modem is still active.
 do not reset your hardware if it is also your modem. Because when you reset it, all configuration of  your modem will be lost, including your user name and password provided by your ISP.
Feb 04, 2011 | Dynex Wireless-G Broadband Router
For Serge : Over here one more question arise that why would I need router,when every thing available in DSL modem like Wireless connectivity,router and main feature is modem,so I can skip the linksys...
Depending on the make and model of your modem that you are referring to will determine if it has routing capabilities as well as wireless etc.
If so then getting another router that has wireless and other options is a bit pointless unless you are suffering from problems or you want to get it to replace it.
I did this myself ( replaced an old router that I got from my internet service provider ) due to the one they supplied being rubbish hence why I got / replaced there router with a netgear / or linksys one ( possibly draytek )
If the modem you refer to does the routing , wireless etc then yes you can get a switch ( however many ports you want ) and connect the router / modem to the internet and have one of the network ports ( the LAN one not the WAN one ) conencted to the switch and then connect all your other devices via the switch with network cables cat 5e or cat 6 ( cat 5e will suffice ) as there is no real need for cat 6 network cables ).
Am guessing the network cables will be UTP category.
If you post back with make and model of your modem - you or anyone else on here should be able to find out if it has the capabilities you mention - which I am guessing is correct otherwise you wouldnt of mentioned it.
The only other reason for maybe swapping the current modem for a linksys or other make of router would be because you wanted a faster wireless connection and if your current modem only supports wireless G and you wanted N then you would either get a new router as you suggested or just get a Pre N wireless access point and disable the wireless on your current modem / router and just use the wireless access point for wireless.
Apr 10, 2009 | Linksys WRT160N Wireless Router
How do I wire up a cat 5e socket to extend my network.
hi, good morning, i'm here to help, the modules should be color coded and the cat 5e will have the same colored wiring when you strip off the jacket, you should use a puch down tool, punch down the 5e wires into the corresponding colors of the module, strip a small portion of the 5e jacket but not the inner pairs of cable, untwist the inner cables and insert and punch down the pairs, the modules should come with some kind of instructions, please let me know if i can be of anymore help
Mar 19, 2009 | Computers & Internet
We are been told to use cat 6 on a project
Shielded cabling, of one type or another, has been the preferred cabling infrastructure in many global markets for many years. Cables described as foil screened unshielded twisted-pair (F/UTP) and fully shielded cables with an overall braid screen plus individual foil shielded twisted pairs (S/FTP) are now gaining popularity in markets where unshielded twisted-pair (UTP) cabling has traditionally been the most common solution.
This rise in adoption is tied to the publication of the IEEE standard known as 802.3an 10GBASE-T and this emerging application's sensitivity to noise from adjacent cabling. This noise from adjacent cabling is known as alien crosstalk. Screened and fully shielded 10 Gb/s cabling systems, such as category 6A F/UTP and category 7 S/FTP, are all but immune to the alien crosstalk that presents problems for category 6A UTP cabling. These cabling systems can help reduce the size and cost of pathway spaces due to their smaller diameters.
Even as cabling installers and their clients increasingly enjoy these benefits, confusion surrounding the bonding and grounding of screened and shielded systems has caused some to avoid them. This concern is unfounded, as advances in screened and shielded cabling systems have simplified bonding and grounding methods tremendously. Today, the installation and bonding and grounding/earthing of F/UTP and S/FTP cabling systems requires little additional effort and expertise over UTP installations.
Jan 07, 2009 | Dynex 7' Cat 6 Network Cable - Gray
I want cataloge fore cat 5e
Hi Friend,
Here's the catalogue. The above links have information for cat 5e cables and cabling systems.
If you need any other info pls. feel free to contact.
Dec 23, 2008 | Superior Essex Marathon LAN Cat 5e Bulk...
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
How to wire up a cat5e faceplate with cat 5e wire
If you want to learn how to wire cat5e, here is a video:
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
309 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Prashant M
Prashant M
Tech support
Tech support
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
