Question about Emerson Televison & Video
I have an emerson LC320EM2 32" flatscreen and the picture is bigger than the screen. We've tried to use the format button but we can't change the size back to normal. Any ideas?
SOURCE: The picture size has changed
The problem has been resolved on it's own. I'm guessing that maybe my cable company had changed the display setting on some of the stations. The picture of stations that I noticed the problem on appear to be within the screen.
Posted on Feb 08, 2009
  • 736 Answers
SOURCE: my screen size is in the 2X mode. I cannot get the
the bottom half of the remote slides down ... that will reveil lots of lesser used controls including zoom .. you can also get to zoom via the menu system .. but its easier to just slide open the bottom cover on the remote and push zoom ..
Posted on Sep 28, 2009
Testimonial: "I forgot about the sliding door. I am an idiot. Thanks for your help. Now I just have to figure out out to close it out. It seems to stop at 2X af"
SOURCE: Format not supported when i try to use my emerson
That usually means the "Resolution" is set too high. Try to start in SAFE MODE, press F8 at bootup, and choose, Standard VGA Mode, or boot to the safe mode desktop, then set resolution for say 800x600 32bit. Then reboot. Hopefully you should now be OK.
Posted on Feb 14, 2010
bshldn
  • 736 Answers
SOURCE: 2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Posted on Nov 09, 2010
bshldn
  • 736 Answers
SOURCE: I have a Mitsubishi WD-73737
I've seen that happen on equipment that has automatic signal detection. Usually this option is available when connecting the equipment with an hdmi cable. The setting can either be on the television or the cable/sat box or both. You have to disable the automatic signal detection signal on both the television (if the television has one in the setup hdmi menu if there is one) and on the cable/sat box. Further you have to choose a resolution on the cable/sat box normally 1080i or 720p fixed. Disable the 4:3 override if there is one. Save and lock in the settings and you should be all set.
Posted on May 07, 2011
How can I get a full picture on my TV?
Buy a programable remote with a format button on..after programming for your tv..use the format button to change the screen size
Aug 15, 2014 | Emerson Televison & Video
How to change picture format for lc220em2 emerson
1. You need OEM remote (universals do not work). Link below to purchase.
2. Press the FORMAT button on the remote. SYLVANIA NH001UD Emerson LCD TV Remote Control
Nov 02, 2013 | Emerson LC220EM2 Remote Control
Emerson 32 HDTV LCD...my picture is smaller than the screen. How do I make the picture fit the screen. I'm missing a few inches of the images on both side...?
Most Emerson remote controls have a "FORMAT" button. Each button press cycles through TV Screen aspect ratio choices, such as Normal, Movie Expand, Wide, Zoom, etc. Pick one that fills your screen. You will probably have to change this setting again, depending on the signal source or channel selected.
The button cycles through the choices in a loop, so you can always get back to Normal.
Mar 24, 2013 | Televison & Video
I have a 19in Emerson Flat Screen TV that I am using as a PC Monitor and it isn't using the full screen. How do I fix it to use the whole screen?
You might not be able to. If the screen size doesn't adjust with the wide/view mode/picture format button on the television remote control you have to change the resolution on the pc. You right click on an empty spot on the desktop, choose properties, and then choose the settings tab. A lower resolution will cause the image to fill the screen but the icons get really big. The image isn't as refined. However you may be able to play around with it enough to find a good enough resolution and a view mode with the Emerson remote that will work out for you (a combination of the two).
May 31, 2011 | Televison & Video
I am trying to hook up my PS3 into my room (Emerson 22 inch flatscreen with HDMI) I am plugging it in with the HDMI cable when it says "Resolution mismatch!" Is that because it was previously on...
This is because your Emerson does not support full HD (unlike your 52").
To fix this:
i) Make sure your PS3 is off (showing red light) ii) Hold down the power button for 5-6 seconds until you've heard two beeps
You should now be able to reset your video options - make sure 1080P is not checked and you should be able to use your PS3 fine with your Emerson.
When you reconnect to your bigger TV, do the same trick with the power button again and turn 1080P back on.
Mar 06, 2011 | Video Game Consoles & Games
Where is the lamp on my Emerson flatscreen tv
What ur tv problems?Tell me,i will tries to help u.Sorry LCD tvs or Plasma tvs don't have lamps.It have floorestscents bulbs tubes that are intergraded inside to the LCD or Plama screen panels itself.
Oct 16, 2010 | Emerson LC320EM8 32 in. LCD TV
Can't get picture to fill entire screen on Emerson 32" LC320EM1
Hi
On the remote there's a button labeled "screen mode". Depending on what you're watching this will change the screen to what you like.
Jun 05, 2010 | Emerson LC320EM8 32 in. LCD TV
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Televison & Video Logo
104 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
