Question about Toshiba Computers & Internet
Power problem power...its sometimes open then after 5 seconds automically off
  • Toshiba Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Dec 12, 2012
What is the difference between Manual vs. Automated Testing?
Difference between Manual and Automation Testing is the pillar of Software testing, because whole testing is based on Manual and Automation Testing. In a project you can do either Manual or Automation Testing and you can also do both Manual and Automation Testing simultaneously.
Complete Difference between Manual and Automation Testing
Manual Testing Automation Testing 1. Manual Testing is a process which is done manually. 1. Automation Testing is a process which is done by the help of automated tools. 2. All the famous phases of STLC like test planning, test deployment, result analysis, test execution, bug tracking and reporting tools are obviously comes under the category of Manual Testing and done successfully by human efforts. 2. In Automation Testing all the popular phases of STLC are done by various open sources and purchased tools like Selenium, J meter, QTP, Load Runner, Win Runner and so on. 3. Manual Testing is a start of Testing, without this testing we can't start Automation Testing. 3. Automation Testing is a continuous part of Manual Testing. 4. In Manual Testing testers are allowed to do Random Testing to find the Bugs. 4. In Automation Testing we always test through Running Scripts. 5. In Manual Testing we find more bugs than automation by Error Guessing. 5. In Automation Testing we test the repetitive functionalities of the application. 6. It takes lot of time. 6. It takes less time. 7. Manual Testing would be run sequentially. 7. Automation Testing is done on different machines at same time. 8. Regression Testing process is tough in Manual Testing 8. Regression Testing process is easy in Automation Testing by Tools. 9. It is not expensive. 9. It is expensive. 10. More testers are required in Manual Testing because in this testing test cases need to be executed manually. 10. Few testers are required in Automation Testing because in this testing test cases need to be executed by using Automation Tools. 11. It gives low accuracy result. 12. It gives high accuracy result. 12. It is considered as low quality. 12. It is considered as high quality. 13. In this Testing we cannot do batch testing. 13. In this Testing we can do multiple types of batch testing. 14. It is considered as less reliable. 14. It is considered as more reliable. 15. No need of programming in Manual Testing. 15. Need of programming is must in Automation Testing. 16. It is done without interaction of any Tool. 16. It is always done using tools.
Aug 24, 2016 | Microsoft Video Game Consoles & Games
Are there any other names that home automation is known by?
home automation is sometimes referred to as domotics
Jan 30, 2013 | Home Automation
My tv flashes about every 5 seconds
Please try to open the back cover and look for the power supply board..(it is usually found directly connected to the power cord)..
Then check the condition of capacitors on the power supply visually..
If it is look like leak or bulged try to replace it to fix your TV..
Dec 19, 2011 | LG 42LG50 42 in. LCD HDTV
I turn my ps3 on, and the main menu never shows up. all i see is that wavy thing (that the menu usually shows up over) and nothing happens. then the only way i can turn the system off is by flipping the...
Ok, what you need to do is re-install the system software, I will talk you through it. WARNING! This will erase your save games and other data you have on the PS3!!
Step 1. Turn the PS3 on at the back but leave it in standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, beep 5 seconds later and then once more 5 seconds after that. Release the power button.
Step 3. Press and hold the power button again. It will beep once when you first press it, beep again 5 seconds later and then about another 5 seconds later it will beep twice quickly. When you hear these 2 quick beeps, let go of the power button.
Step 4. The PS3 will start up and ask you to connect a controller via USB and press the PS button. Do this and then move onto the next step.
Step 5. The recovery menu will load. Select option 5 "Restore PS3 System". The console will go through an automated restore sequence and re-write its software. It will then restart and hopefully after you have entered the time, date and username information start normally.
If you need any more help, please reply here.
Thank you for using FixYa
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
When I lock the doors, after 5 seconds without doing anything is unlocked
replace the weakened door lock automated module with a new one for it will not hold in the lock position no longer
Jun 08, 2010 | Daewoo Lanos Cars & Trucks
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Send me the related titles to develop a projects in c,c++,vb
in C/C++ you can have projects related to system/hardware, maths and engineering.
while in VB you can create Database/Interface oriented projects. The related titles are :--
C/C++
1. Serial/Parallel port communication
2. Automatic weight entry from Weighing Machine
3. Your weight on different plannets
4. PC based PH Meter
5. Electronic Punching/Kicking pad to measure power of martial arts/boxing players
6. Electronic man counter
VB
1. library management system
2. Video Library
3. Virtual Library
4. Automated Parking Management system
5. Automated Car security check (Bomb finder)
6. Automated ID Card generator
7. Face recognition responsive system
Dec 08, 2008 | Computers & Internet
LG 8300 vx
THe phone is very defective. I would see about a refund.
Apr 02, 2008 | LG VX8300 Cellular Phone
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Computers & Internet Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
