Question about Dell Dimension 4600 PC Desktop
I'm having trouble with figureing how to set up my microphone to the computer
  • Dell Master
  • 27,725 Answers
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Posted on Dec 12, 2012
I can't get the webcam to work when I am calling someone on skype
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam. Click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X right click to reinstall drivers or update driver W7. Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam. Click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service Open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call. Make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment. Click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings. Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or Select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it Hope this helps.
Dec 18, 2012 | Microsoft Windows Vista Home Premium with...
MY MICROPHONE DOESNT WORK
Go to Hardware and Sound in Control Panel, choose Manage Audio Devices, select Recording, click on Microphone and test the microphone built into your computer. If the results are unsatisfactory, buy an external (USB) microphone and plug it in.
Sep 19, 2012 | Toshiba Tecra A3 Notebook
How do I get my Behringer C-1U mic to work?
I'm having the same problem, however I can say that Phantom Power is out of the question. the c-1u is a variation of the c-1. The difference is that the u doesnt require phantom power
May 06, 2012 | Behringer C1U Microphone
We have a linksys BEFSR41 4port cable/dsl router. It was in the other room, and the four devices (xbox 360, ps3, 1 desktop & 1 laptop computer) used a hub before hitting the router (mainly because of...
The pc with vista,is the network set too public or home in network settings?Set it to public,also the pc with win7.
Check that the routers firewall is allowing everything you have hooked to it or disable it.
Last if your famiiar with ip address in the router try to release and renew the ip address.
Jul 20, 2011 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Do I need more than one Wii remote for Band hero Wii????
you need a wii remote for each instrument and the microphone. you need one remote for the drums, one for the bass guitar player, one for the guitar, and one in close proximity to the microphone user. you have to set a wii remote near the microphone once the microphone is plugged into the USB port in the back of the wii console. i think there is something like a 10 foot radius meaning if the wii remote is too far from the microphone it will disconnect. so you can do only one instrument per wii remote you are using.
Dec 25, 2009 | Nintendo Rock Band for Wii
Cannot setup C01U Microphone with Adobe Audition2.0.
Try to disable your laptops build in mic through the recording options on your computer. It worked for me
Apr 06, 2009 | Samson C01U USB Condenser Microphone...
Hooking up a microphone to a computer
Any mic is fine. You will have to enable it in the sound mixer though.
Goto..
Start - Control Panel - Sound
Select Recording and then select Microphone.
Select Configure at the bottom of that window.
The next window will open and you will see Set Up A Microphone.
It will walk you through setting it up and making sure it is active.
May 08, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
149 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
