Question about Radio Communications
Where could I find a linear amp for my pc78xl
  • 63 Answers
Get a fatboy thats an amp smaall 300 watt that all you need fatboy.com
Posted on Mar 11, 2015
    Top Expert:
  • 14,553 Answers
Most repair shops sell or know where but you can find them new on the internet, try Google or one of the search engines, the radio will if stock have to have the output adjusted to use the amp.
Posted on Dec 12, 2012
I need a owners manual for a swan 1200x linear amp
if the following search on google does not supply an answer it isn't available.
swan 1200x linear amp manual
Dec 26, 2014 | Radio Communications
Schematic for pc78xL won,t turn on
there gould be a number of reasons for it not turning on but the one I am thinking of is the reverse polarity diode. If it is burnt your radio will not turn on look in the area of your where your power wires come in .You should see a single black zenner diode.Replace it and it should turn on .
Jan 21, 2012 | Uniden Bearcat Pro PC78XL 40-Channels Base...
What does linear mean?
The word linear comes from the Latin word linearis, which means created by lines. In mathematics, a linear map or function f(x) is a function which satisfies the following two properties:
  • Additivity (also called the superposition property): f(x + y) = f(x) + f(y). This says that f is a group homomorphism with respect to addition.
  • Homogeneity of degree 1: f(?x) = ?f(x) for all ?.
Sep 23, 2010 | Computers & Internet
Need more talkpower without a linear amp
Send it to a CB shop and ask em to peak it and tune it,shouldnt cost more than 75.00
Apr 01, 2010 | Galaxy Radios DX- 88HL Base CB Radio
7250PE preamp works, power amp both channels out. Could this be a fuse? Thanks, Mike
Could be possible considering the power amp would be running on a higher voltage rail than the preamp. It really depends on how the manufacturer designed the power supply. If they just have a step down transformer driving a bridge rectifier and then derive the voltage for the preamp by regulating with some for of linear regulator than the fuse theory is not correct. Best bet would be to pop it open and examine what comes after the transformers secondary. Depending on the power this amp is capable of the power supply could be a switch mode instead of linear. You can tell by the weight of the amp, heavy = linear light = switch mode.
Feb 09, 2010 | NAD Audio Players & Recorders
Mic not Keying up
Sounds like you are not modulating well. try adjusting your amp.also, test your antenna for wire breakage and, make sure that your mic has good wires as well.
Jan 22, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Amp
It should have a blue wire from the harness on the back of the player for turning on the amp, it may also be labeled "antenna" or "power antenna" or "P con". That is the one to run to the remote turn on of the amp.
Mar 10, 2008 | Phase Linear UDV9010 Car DVD Player
Cb radio
Hi, A couple of switches and knobs you can check (if present in your rig): 1. auto noise/noise blanker switch - try off position; 2. dynamic squelch control - lower down setting; 3. RF gain - should be at max (clockwise); and 4. Delta Tune - normally should be centered. Hope this works out for you and give you an idea where to start. Good luck and pls post again how things turn up. Kind regards.
Aug 07, 2007 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Radio Communications Logo
73 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
