Need manual for nakamichi mini speaker not sure how to work radio
Need manual fo ra nakamichi mini speaker I can;t figure out how to use th e radio also I feel like There are ot her things it will do that I'm missing out on,
2 Suggested Answers
SOURCE: Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Posted on Jun 26, 2008
Nakamichi mini speaker has crackling noise as soon it is switched on
check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Audio Players & Recorders
Th-m303 theater system no sound coming from all 5 speakers
Review the wiring connection maybe loose contact and check the speakers If it workings by testing the one not working to put or interchange it to the working speakers, so you can sure if the speakers is fine. Check also the selector assignment.
Hope it may help you;
Regards;
VOTIT
Jan 11, 2009 | JVC TH-M303 System
I Can't Set The Alarm
Here you go. Click on instruction manual download. Hope this helped.
http://www.generalmanual.com/Radios-Boomboxes/JVC-RA-P11-Portable-Audio-System.htm
Jan 05, 2009 | JVC RA-P11 Portable Audio System - Made...
Polk speakers with Windows Vista don't work
I doubt the speakers need a driver. Is there output from the soundcard? Connect the speakers to an alternate audio source, such as the headphone jack of a CD player or radio. If the
speakers produce sound, the problem is probably
with your soundcard. Recheck your soundcard
installation and setup procedure. Consult the sound
card’s manual. Check the “mute” and “volume” controls on your
soundcard or media player software and keyboard.
Are the speakers connected properly? Make sure the
plugs are securely connected in the proper location
according to their colorcoding and the diagram on th
front of this manual. Make sure the left speaker wire
with the white stripe is connected to the (+) speaker
terminal on the subwoofer.
Dec 03, 2008 | Polk Audio AMR50 Computer Speakers
I need the code for my car stereo
GM radio codes can only be obtained from a dealership. Each car has a unique code based on its VIN number.
Jul 30, 2008 | Car Audio & Video
Nakamichi Sound Space 8 System
NEW CABLE FROM NAKAMICHI IS £150 . INSTEAD JUST CUT THE METAL SHIELD OFF ANY CD MINI DIN CONTROL CABLE WITH A JUNIOR HACKSAW AND IT WILL FIT PERFECTLY (IT ONLY GOES IN ONE WAY BECAUSE OF THE WAY THE PINS ARE LAID OUT!). I USED AN OLD MAC DIN PLUG BECAUSE IT WAS 3M LONG! WORKS PERFECTLY!
DS
Jun 01, 2008 | Nakamichi SoundSpace 8 System
In what mode do hear regular tv through the system
DO NOT PLAY THE TV SPEAKERS AT THE SAME TIME AS THE SoundSpace System!!! Damage will result to the SS if you do. You MUST mute the tv speakers!! This information is in the manual.
Jan 10, 2008 | Nakamichi SoundSpace 8.5 System
I do not hear any music through my 10" M Audio Subs (M Audio Sound System)
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
You mentioned you need a 4 channel amplifier make the two, dual voice coil subs operate. The is not true and by hooking them up like that, there's a chance of damaging the subs. The reason is that the dual voice coils are interwoven and they have to get electrically identical signals or they fight against each other. The can mechanically fail, then, electrically fail, then even damage the amp too.
Nov 21, 2007 | Nakamichi PA-504 Car Audio Amplifier
How do I set the clock???!!!
Come on, someone, pleeeeease???
It's driving me crazy.
Nov 06, 2007 | Nakamichi CD-35z CD Changer
543 people viewed this question
 Grubhead
Grubhead
