Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
Swingline electric stapler model42130 unable to refill
My Swingline electric stapler Model #42130 is out of staples and I cannot figure out how to refill. Thanks,
  • 1 more comment
  • Anonymous Feb 18, 2009
    "swingline electric stapler model42130 just stopped working and it is fairly new...not high volume useage"
  • Anonymous Mar 12, 2009
  • kozmikkurt May 11, 2010
    Do the directions or operator manual say anything about reloading instructions and what type of staples to use?
4 Suggested Answers
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
Posted on Mar 14, 2009
Hugh fulton
  • 62 Answers
SOURCE: Where can I get staples swingline stapler
Asssuming that you are in Australia , you could go to Bunnings and ask them or they might point you in the right direction.
Good Luck
Posted on Sep 13, 2009
  • 4 Answers
SOURCE: my swingline electric stapler model 42130 is
I just took this model apart. The battery cover slides off. There are two scews on the side and 6 on the base i think. 4 our hidden under the sticker. This will get you inside to see where it is jammed.
Posted on Sep 30, 2009
Swingline model 67 broken staple driver part replacement
you buy a new stapler . they do not make that part as a replacement
Aug 27, 2016 | Swingline 06702 Model 67 Electric Stapler
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
We have a Swingline 690 electric stapler in our office. We are unable to get the stapler to work after loading staple cartridge. We followed the directions and made many attempts to load. There does not...
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Mar 30, 2011 | Swingline Portable Electric Stapler
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
My swingline electric stapler model 42130 is jammed is there a manual release button the one on the back doesnt work
Taking the stapler apart is a complex task if you can figure how to do that.To dismantle the stapler, slide back the top, remove two small screws on both sides, six on the bottom, four of the screws are under the sticker so you must peel off the sticker, you must also remove the sticker on top. There two tiny shinny screws at the bottom once you are inside. Now you have access to more screws you can take off to get to the staples place where the jam is. Watch cables where they are plugged to in case they come off. If you are are a mechanical technician or technically inclined you might be able to fix this yourself but you must be very patient.
Aug 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Swingline Stapler 900XD -
Help! I have a swingline 900XD and the device that holds the staples in place is missing. Does anyone have an idea how to fix it???
Jun 10, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
792 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Joe Ball
Joe Ball
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
