Question about Hoover HVP16 Front Load Washer
Error 5 what does this mean? Ive tried powering down, cleaning the filter to no avail. can anyone help please?
  • 3 Answers
Error 5 refers to the temperature sensor.
On my machine the wire to it had broken at the spade connector connecting to the sensor.
You can access it easily by removing the back panel, the sensor is at the bottom of the drum with one white wire coming from it. I replaced the connector with a sleeved 1/4" spade connector bought from Halfords.
The wire is of poor quality so try to support it so vibrations dont cause the cable to fracture again
Posted on Jan 07, 2010
I have an error code LO on my pool heater
LO means different things on different brands so please clarify which brand and model. The most common meaning is low flow from the filter system. Try cleaning the filter...or add the requested information please.
Aug 13, 2014 | Pool & Spa
NEC VT440 projector problems can you help
Please check its vantilation fans, are they rotating or not?
Jul 24, 2008 | NEC VT460 Multimedia Projector
Beko condensor dryer not emmiting any heat but still 'working'
Stat or heater check power if it is a 220 volt machine may have one side down on power
Dec 03, 2013 | Zanussi TC7102W Electric Dryer
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
What does f3 flashing mean?
F3 error code means your washer has not drained. To fix the washing machine error code is simple and straight forward. Simply remove the drain pump filter and slide the filter out and clean the debris inside. The filter in most cases is on the lower bottom panel. Simple depress the tab and fold the access door down. The washer drain pump filter is a white handle twist the handle to remove the filter. You may also find an article of clothing trapped down where the filter is like socks or change etc. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Jul 08, 2011 | Asko W6222 Top Load Washer
I have an AC unit with the model # PDH12K3SD-C the unit stops working and flashes an error cod = "06" anyone know what the error code means?
According to the Owner's Manual if the Error Code flashes "06" the O.D. coil Temperature > 175 Deg
F for 2 consecutive minutes. (Heat Pump models only).
The action taken by the unit is Alternate flash set point and error code. Shut unit down for 5 minutes, then try again 2 times, if fails the 3rd time, then shut down unit.:
All of this is can caused by several things:
• Dirty filters
• Dirty coil
• Fan motor failure
• Restricted air flow
• Improper refrigerant charge
• Restriction in refrigerant circuit
The dirty filters, dirty coil and restricted air flow you can troubleshoot and solve yourself. The reaming ones should be handled by a an authorized service technician.
Here's a link to your Owners Manual, that you can download and print for future reference.
http://www.ajmadison.com/ajmadison/itemdocs/92008705_9-07_PTAC_IO_manual.pdf
Hope this helped to to troubleshoot and solve the problem . Please let me know. Thanks.
Jun 10, 2011 | Friedrich PDH12K3SD Air Conditioner
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
My PIU Cube 16 Olimpia Splendid portable air conditioner is displaying an error message f1, can anyone solve what this means? Thanks
It means 'Dirty Filter' once cleaned you must press and hold down the 'On' button for 5 seconds and the message will remove.
Feb 24, 2011 | Heating & Cooling
Dell 926.... the printer will not acknowledge that a new cartridge has been put in. It will not work. previously had the error code 1203, a short circuit in print head. That has now disappeared. Help...
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Aug 10, 2009 | Dell 926 All-In-One InkJet Printer
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hoover HVP16 Front Load Washer Logo
133 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
