Question about KitchenAid Kitchen Aid Mixer Stainless Steel Bowl 5 Quart
Bowl lift on my kitchenaid 5 profesional is slipping
  • KitchenAid Master
  • 1,280 Answers
Replace the plastic bowl lift part on that crankhandle inside the pedestal.
Posted on Dec 01, 2013
  • 185 Answers
SOURCE: kitchenaid stand mixer bowl lift not working
Yikes!!! How old is your mixer? In most cases in a bowl lift model, the plastic lift mechanism breaks. It is not hard to fix or get fixed the parts are inexpensive and it is totally mechanical not electrical to fix. Go to kichenaid.com and then click on support the drop down menu will give you a selection to get manuals and user guides, click that selection, then you go to a page that will ask you for model number, look under your mixer and use the model number on the white sticker. you will be able to download the parts list for that model. The parts list will show how the lift mechanism operates and how the parts go together. the next page will give you a part number for the parts involved in the lift mechanism. Now go on ebay or amazon and type in the part numbers that you need, you will find almost every part involved in the lift mechanism, Now get a screwdriver a punch and a non metal hammer, once you have the part list and you see how it goes together you will be able to disassemble the lift and repair. you can fix it for about $15.00 and an hours time. That does not include the wait time for parts shipping to you, that will take about a week. You can also call kitchen Aid and see where your nearest approved repair center is and take or ship your system there, "for the price of your first born". But while you are there you can buy the parts that you need. There are not a lot of authorizes centers around every corner. if you have a warranty definitely call Kitchenaid, they have one of the best "No Hassle" exchange for another mixer programs in the biz. The negative is that it ABSOLUTELY ends on day 365 of your one year warranty.
Posted on Sep 15, 2012
SOURCE: My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Posted on Jan 25, 2010
  • 11800 Answers
SOURCE: Hello, I just got a
You can't fix that: the parts have been produced this way - the manufacturing has been of a low quality, with excessive tolerances. If it's very annoying you could add yourself a plastic shim - of your creation - on the inside of the slider, but this is just a kludge for which you will have to completely dismantle it.
Posted on Dec 09, 2010
  • 130 Answers
SOURCE: KitchenAid® Professional 600? 6-qt. Bowl-Lift
nice machine!! enjoy using it. I assume you have no problems with it since no problems are described!!
Posted on Feb 23, 2011
SOURCE: Bowl Lift
I had this problem and fixed it with some grease on the bowl lift lever. I used coconut oil for the grease as its obviously food grade. I greased the exterior which was the cause of the problem and the inside of the bowl lift lever. To get to the inside you can flip the mixer over (unplug it first) and remove the base with 3 screws to improve access. If further disassembly is reqired the C clip can be removed from the bottom of the mechanism and then slide the spring out. The bowl lift stand then comes out (you need to remove one screw if it catches) and you can easily reach inside. When putting it back together get someone with small hands. The C clip is easy to drop in the machine and easily lost.
Posted on Feb 15, 2012
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
What model kitchenaid was made in december of 1973?
Is the brushed band around the head missing or worn off? The model is on that band. If it worn or missing in order to correctly answer your question I need more information. Is your mixer a tilt head or a bowl lift variety? Did you look on the bottom of the base for a serial number? Some models had them there. Can you describe the ceramic piece a little better? Many models shard the same internal parts and it might not be too difficult to locate that part.
Aug 03, 2014 | KitchenAid K45SS Classic Stand Mixer
Where would I find a bowl lift replacement mechanism for a kitchenaid 5 qt mixer model K5SSWW.I have a kitchenaid 5 qt mixer model K5SSWW. I need a bowl lift mechanism replacement part but can't find this...
The model number seems to be valid-but given the age of the unit few parts are readily available. You might want to try eBay or a used appliance store (or even Goodwill) to find a donor machine.
May 02, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid bowl lift mixer bowl support
David, that is a 6 quart mixer but uses the new 7&8 Quart mixer parts, KitchenAid has been covering those with a really long warranty, I want to say 2-5 years, and none of the service centers have seen them come in yet. That is not a problem on the 5 or 6 quart older style bowl lifts that we have ever came across, the best thing to do would be to contact kitchenAid directly. Their number is 800-541-6390.
Mar 17, 2014 | Food Mixers
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Feb 11, 2011 | KitchenAid KP2671 Professional 6 Series...
The wisk is hiting the bowl how can i adjust
Hi FMOINIZ, by the symptom you are describing, you need to adjust your mixer’s Bowl to Beater Clearance. This is quite an easy task, and is explained in your Users Instruction manual that came with your mixer. If you do not have one, you can easily download a PDF version from the KA website at: ’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (4) KP50PSWW0.pdf (2930.74 KB) and save that file to your PC. Turn to Page 11 and you will find the instructions for adjusting the Bowl-Lift model mixer head height.
But to save you some time, I have extracted the instructions below:
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 26, 2009 | KitchenAid KP50PS Professional 5 Series...
KitchenAid Kitchen Aid Mixer Stainless Steel Bowl 5 Quart Logo
67 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
