Question about KitchenAid Professional 5 Plus Bowl-lift Stand Mixer Kv25g0xmc Metallic Chrome
The bowl lift on my kitchenaid 5 profesional is slipping , won. raise all the way up
When bowl is attached it is ok when bowl has ingredients in it sometimes the hande slips and won't lift all the way
  • KitchenAid Master
  • 1,314 Answers
Bowl lift plastic gizmo on the shaft is breaking, fit a new one.
Posted on Dec 01, 2013
SOURCE: the attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Posted on Feb 12, 2009
clyde2j2
  • 137 Answers
SOURCE: bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Posted on Mar 28, 2009
SOURCE: Looking for KitchenAide KSM50HDPBK User Manual
when you lower the bowl, there is a screw just above the mounting plate. Adjust this very very slightly. Lift bowl with beater attached with out turning on the machine to test first, after you have adjusted.
Posted on Jun 11, 2009
SOURCE: My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Posted on Jan 25, 2010
  • 11800 Answers
SOURCE: Hello, I just got a
You can't fix that: the parts have been produced this way - the manufacturing has been of a low quality, with excessive tolerances. If it's very annoying you could add yourself a plastic shim - of your creation - on the inside of the slider, but this is just a kludge for which you will have to completely dismantle it.
Posted on Dec 09, 2010
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
How do i adjust the bowl height on an ksmc5os?
I'm not familiar with your model but on stand mixers with crank handle bowl lift there are 2 places for it to be. With bowl lift down there can be s screw straight in from the front on the pedestal just above the bowl lift sliding bracket, the full range of adjustment is half a turn, anti clockwise to raise, clockwise to lower. The other one is a small screw sticking down from under the gear case where the bracket that carries trhe bowl slides up and down. Clockwise to lower, anti clockwise to raise.
Aug 19, 2014 | KitchenAid KSMC50S Commercial Stand Mixer
Poor Mixing
Can you tell me the exact type you have and say exactly what you did to it to change it?
Mar 09, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Bowl lift on my kitchenaid 5 profesional is slipping
Replace the plastic bowl lift part on that crankhandle inside the pedestal.
Dec 12, 2012 | KitchenAid Kitchen Aid Mixer Stainless...
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
Mixer blade is chipping
If it is a tilt head mixer then adjust the screw which can be seen by tipping the head back and looking into the pivot point. Turn the screw CCW to raise the head and prevent the paddle from hitting the bottom of the bowl.
If it is a lift bowl mixer there is an adjusting screw on the frame of the stand behind the bowl holder mechanism. It rurns a cam which adjusts the height of the mixer.
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Jun 11, 2009 | KitchenAid KSM50HDPBK Stand Mixer
Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Mar 20, 2009 | KitchenAid Artisan Series Tilt-Head Stand...
The attachments move up on the shaft
Jan 15, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid Professional 5 Plus Bowl-lift Stand Mixer Kv25g0xmc Metallic Chrome Logo
120 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
