Question about Kenmore Elite 45986 Front Load Washer
FH error on display - Kenmore Elite 45986 Front Load Washer
  • Kenmore Master
  • 5,101 Answers
An FH error usually means low water flow into the washer. This can be caused by debris in the filters between the intake hoses and the washer, closed water valves, low water pressure or a problem with the system that checks the water flow.
Some intake hoses when they detect a leak will seal themselves. So you may want to replace them. Shut off the water valves and remove the hoses from the washer. Check the filters for debris. With a bucket under the hoses, open the valves and check the rate of water flow. You may want to check the filters on the valve side of the intake hoses after turning the valves to off again. If water flows into the washer and then into the drain, reset the drain hose. The outlet of the hose should be above the water level in the washer. Otherwise, the water will suction out of the unit.
If these parts are fine and there is still no water flowing into the machine, the intake valve is faulty.
If you are getting the error when the washer is full of water, it's the pressure switch or the flow meter. In a few cases, the cause is actually damage to the air hoses connected to the pressure switch. If one of these thin tubes is leaking, the pressure switch will not work properly.
I hope this helps.
Posted on Dec 12, 2012
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Timer display blinks fh on maytag epic front loader
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
F and H keep coming up on screen
The information provided is general. For information specific to your washer please resubmit the question, including the model number.
The "F" is at the beginning of all error codes. This indicates the a Fault has taken place. The second number or letter indicates what the Fault is.
FH : Is displayed when no water has been detected entering the washer.
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display
Unplug the washer from its electrical source and wait for 30 seconds.
Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
Check all hose connection and valves, both hot and cold, are turned on completely.
Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
Hope helps (remember to rating this free answer and leave a comment)
Sep 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
Keep getting FH code. Have cleaned inlets and checked hoses. Water is coming in,sounds right but then goes to FH again.
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 06, 2011 | KitchenAid KHWS01PMT Front Load Washer
FH error appears about a minute or two after I select the "on" button
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Jul 19, 2011 | Kenmore Elite 45986 Front Load Washer
What does code fh mean?
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the follow link for additional details: support/error_code_HF
Hope this helps (remember to rate and comment this answer).
Jun 28, 2011 | Whirlpool AWM8103/1 Front Load Washer
With 26 minutes remaining FH appears where the time is displayed and the wash stops. What does FH mean
Kevin
May 03, 2011 | Washing Machines
My washingmachine started to beep and FH showed up on the screen. What does FH stand for?
Hi
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Feb 16, 2011 | Whirlpool Washing Machines
Washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Sep 19, 2009 | Whirlpool AWM8123 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
70 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
