Question about Vizio XVT553SV 55 in. LCD TV
Vizio downloads firmware every time it is turned on
Every time I turn on the Vizio set it downloads firmware; I infer this from its behavior. This behavior is a bit different every time I turn it on. Sometimes it appears to work normally and I can watch cable OK, but the problem is revealed by its inability to connect to the wifi - it shows the yellow symbol, no green bars. Other times the lower lower part of the screen is full of colorful vertical bars, while the upper part of the screen has a normal picture (from cable). Other times the cable picture freezes, though the sound track continues. Generally, after several minutes (it varies) the set turns itself off and the Vizio symbol blinks several times and the set turns itself on again; then, it works fine and can connect to the internet (Netflix) by wifi until it is turned off. When it is turned on again, same story all over agian. Vizio support had me reset the memory to factory default, but that did not solve the problem. SInce I use the Vizio mainly for Netflix, this is extremely annoying. I bought the set in Nov. 2010 and I think I have had this problem pretty much all along but not as frequently and thought it was an issue with my wifi.
    Top Expert:
  • Vizio Master
  • 75,311 Answers
Firmware corrupted. A reinstallation is necessary. Contact any service technician.
Posted on Mar 04, 2017
SOURCE: vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Posted on Apr 09, 2008
  • 92 Answers
SOURCE: Black showing as red on LCD
this is a LVDS cable issue. All you have to do is call Vizio and they will send out a tech and replace the LVDS cable along with the Main Board. This should resolve the pixilation issue.
Posted on May 20, 2009
Shuttle83
  • 1139 Answers
SOURCE: SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
Axle80
  • 73 Answers
SOURCE: vizio p42 type sp42a nov 2004 hd tv
The sp42a is a plasma tv not an lcd. check the psb voltages first then move onto the ymain and buffers.
Posted on Aug 25, 2009
smervan
SOURCE: Outline of images turn florecent lime/green!
I found out that the main board gets too hot after few minutes that the TV is ON and that causes the interference of voltage, So, I don't know what causes it but my Vizio Tv turned green also and I installed a desk FAN behind the TV and kept it cool. This solved the problem, but as soon as I turn the FAN OFF, TV gets hot and turns green again. I spoke to VIZIO Customer Service and the people that I bought it from; Vizio knew about the problem and offered to fix it, but the wholesaler that I bought mine from is willing to swap it for another one.
I hope this would help to continue using the TV untill the problem is fixed.
Thank you
Shane
Posted on Sep 07, 2009
Volume doesn't work on remote Vizio, only turns off and on, also can't find any buttons. On TV to turn up or down
There were a few Vizio sets that didn't have any controls other than off and on...sounds like you have one, Chances are you have issues with the inferred receiver board.
Nov 27, 2017 | Televison & Video
I hav a vizio tv xvt3d474sv when I turn it on the vizio logo flashes 24 time then shuts down
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2015 | Vizio Televison & Video
Vizio E422AR firmware update problem
see if you can rollback to your previous settings. Hope you backed up before you accepted the download. That's the beauty of restore points
Feb 20, 2014 | Vizio E422AR - 42" Class 42" viewable LCD...
Vizio m550sv turns on and them immediately turns back off
Call VIZIO Support 1-877-698-4946 and discuss the issue. Their sets are run by software "firmware" and it may not have updated proberly when you bought the set. I have had the same problem and it went away after a firmware update. VIZIO will ask you to run a :power discharge" scenario which means you Completely Unplug the unit and PRESS the Power Button on the Back of the Set...HOLDING IT DOWN FOR 3 MINUTES. However, thay may not resolved the issue unitl the firmware is completly updated. This takes a while.
Dec 28, 2011 | Vizio M550NV 55 in LCD HDTV
I have a Vizio Model E420VL and it gets into a state which the audio does not work (from HDMI input #1) and remote control processing in the unit also does not work. I had played around with the side...
hi,
It can be difficult to get things right on the first try. With that truism in mind, Vizio Incorporated includes USB ports on their televisions that you can use to load firmware updates onto the television. Vizio has released firmware updates only for certain television models, and the instructions for installing firmware updates vary slightly by model. To upgrade your television's firmware, you need to download and copy firmware drivers to a USB flash drive and then read and follow Vizio's specific installation instructions for your model.
1. Connect the USB flash drive to your computer
2. Click the "Start" button, and click the "My Computer" icon.
3. Right-click the flash drive, and click "Format" in the menu
4. Select "FAT32" in the drop-down menu, and click the "OK" button. Windows will format your USB flash drive with the FAT32 file system.
5. Open your Web browser, and navigate to the Vizio support Web site at www.vizio.com/support.
6. Click the "Select Your Product" drop-down menu, and select your model of Vizio television from the list. A new page will open that displays available downloads for your television
7. Click the "Firmware Update" link, and save the firmware update file to your computer.
8. Click the "Firmware Instructions" link, and read the instructions specific to your Vizio television model.
9. Right-click the file that you downloaded, click "Rename," and then rename the file to the exact name that is specified in the firmware instructions 10. Right-click the file, and click "Send to" > "E: USB Drive" or whichever drive letter corresponds to your flash drive. The firmware update file is copied to your USB drive 11. Right-click the "Safely Remove Hardware" icon on the right side of the Windows task bar, and eject the device from your computer
12. Disconnect the USB drive, and plug it in to your Vizio TV's USB port.
13. Follow the steps in the firmware instructions to install the firmware update to your television.
Only you can find is the problem with firmware by udating the frimware of your tv. ok
Aug 05, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
I am connecting Yamaha DVD player to the Vizio M420 NV via HDMI. i have a picture but no sound. how do I gain audio when using HDMI?
HDMI has both Audio and Video (High Definition Multimedia Interface) and should carry both. However, I had this problem with a client just the other day and it turned out that the firmware on his TV needed to be up[graded. Different model TV, but I believe you may need to download the latest software/firmware update via your PC and put it on a flash drive and then flash the firmware on your TV to get it to work. Sorry I don't have the specifics; I was stumped and the Time-Warner guy ended up doing it. I hope this at least sends you in the right direction.
James
Apr 17, 2011 | Vizio Televison & Video
Vizio light is flashing on and off and i can't get tv to turn on
You have a bad firmware updated from Vizio, many have this issue and think it is the power board, when it is just horribly written fimware.
If you can unplug the set, wait a few mins, and plug it back in, then eventually it may come on, if it does go into your menu, and select HELP, then select Clear Memory(factory default)
If that works for you, and you have an internet ready TV, do NOT connect the net back to it, or it will download the messed up firmware update again.
Jan 23, 2011 | Vizio Televison & Video
Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Jun 25, 2009 | Vizio VO47L 47 in. LCD TV
Vizio P4 Plasma green blotches
The same thing happened to me Twice!. First time it was under warranty. Now it it out and Vizio has not interest in helping me. The first time the repair man changed the motherboard, which worked for about a year. Looks like I will be buying a new TV soon, but certainly NOT a Vizio, they are junk
Anyone out there know how much a motherboard costs?
Dec 27, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Open Questions:
See all Vizio XVT553SV 55 in. LCD TV Questions
Vizio XVT553SV 55 in. LCD TV Logo
139 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
