Have a 1998 VA1512 that I absolutely love. problem is about a week ago after turning on the receiver a couple minutes in it would start to do this low level rumbling. it did this a few times but after turning it off and moving around the chords so it wasn't picking up any interference from other chords it would eventually stop making the low level rumble. today however it started doing it again and I moved all the cords and power sources away from the sub. I left it unplugged for couple hours and when I plugged it back in this time it made a loud pop and I'm much louder consistent ramble. i then move the unit away from the TV and unplugged the cable coming from the receiver and just plugged it into a different outlet with nothing else plugged into sub except for the power cord nothing else in the outlet. regardless it still kept making a loud pop and consistent loud rumbling. please help troubleshoot this for me. I love my sub. if it needs to be repaired where do I send it since it's old. or is it time to invest in a new 1.
  • 7,627 Answers
I would have that PRINTER exorcised, it's possessed by demons, followed by a burning at the stake.
Posted on Dec 12, 2012
  • 406 Answers
SOURCE: hp printer needs help
Remove the cartridges . and reinsert cartridges .
Ithink it will solve reset problem.
rafique
Posted on Feb 15, 2008
  • 6 Answers
SOURCE: HP Officejet 7410 All-in-one No Power Light
Turn the printer upside down right underneath where the cartridge station is you will find a small white gear...sometime it may be covered with a blue rubber cover.
when you turn the gear ..the barrier in front of the cartridge will go down.
Then do a rest on the printer and then install it.
Posted on Jun 08, 2008
untameddevil
  • 10 Answers
SOURCE: The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Posted on Jul 09, 2008
SOURCE: Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Posted on May 15, 2009
SOURCE: "Turn Power Off then on Again" error
This solution worked for my OfficeJet L7680--good luck!
1: Disconnect the Universal Serial Bus (USB) or ethernet cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB or ethernet cable, and try to print a print job from the computer.
Posted on Jul 07, 2009
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
Power Problem with Fisher RS 9015
Glad it helps, thanks also for choosing Fixya for assistance!
Aug 13, 2012 | Audio Players & Recorders
Wont turn over
The starter is most likely the problem,tap on the starter lightly with a hammer while trying to start the engine,dont get run over doing this it will take two people,if the engine starts,the starter needs replacing.
Apr 25, 2010 | 1998 Jeep Wrangler
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Hello!!! i have a f-150 1998 couple week ago i
Remove front rotors (assuming they are disc - can't imagine they are not) and have them resurfaced at any local shop. Apply anti squeal adhesive to the backside of the brackpads (and shims if they came with them).
Aug 06, 2009 | 1998 Ford F150 Regular Cab
RCA 46'' rear projection TV, dated 1998 won't turn on
Probably a new problem given the age of the TV. If you already haven't done so, try unplugging the power for about 10 minutes, plug back in and try again.
Jul 07, 2009 | Televison & Video
JVC camcorder says "Please Wait"...
PRESET the camera two or three times and try.
Jun 29, 2007 | JVC GR-D270US Mini DV Digital Camcorder
23 people viewed this question
jasbo
jasbo
