Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
I need to connect to http://192.168.0.50 inorder to activate my ne DWL2100 AP wireless access point but the page is not opening.
    Sergeant:
  • 366 Answers
You must connect to your gateway ip address to find your router if you are browsing internet through it.
Run command line: ipconfig will show your gateway.
If you must connect to 192.168.0.50 you MUST be physically connected to it via LAN cable and you MUST be in same SUBNET
192.168.0 .n with mask 255.255.255.0
Change your network connections settings in Control panel for the interface you use: for TCP protocol from any setting you find to a specific IP addrees on same subnet (192.168.0.51) and connect.
Use only IE and have your Java enabled.
Posted on Jan 13, 2009
Can i use the pppoe on dlink DWL2100 ap ???
I don't think that access point has PPPoE. To get PPPoE, you need to get a router, not an access point.
Sep 10, 2013 | D-Link AirPlus Xtreme G DWL-2100AP...
How to config
Try This:
1 connect your DWL2100 to your computer by cable and disable its wifi
2 reset your DWL2100 by holding the reset in for 5 seconds
2 set your computer ip address manually to 192.168.0.67 - (IMPORTANT)
3 open your browser and log into address 192.168.0.50
the DWL2100 wizard page should now open
I have also attached the manual just click on the link below.
Good Luck!
http://ftp.dlink.ru/pub/Wireless/DWL-2100AP/Description/DWL-2100AP_Manual_210.pdf
Jul 28, 2012 | D-Link AirPlus Xtreme G DWL-2100AP...
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
Dell Studio 1535 Wireless Problem
If you are seeing access points, you need to make sure that you are connecting to them. You will get a message that you are connected. If the AP is secured, there will usually be a symbol that looks like a lock and that means that you have to know the name of the AP and also the secuirty key. You have to know that they are open access points, but be careful connecting to one that isn't a public AP. If it is just one in your area , you are technically "stealing" the connection and there have been some cases where people have been charged with theft for using an AP they weren't authorized to use.
Dec 28, 2008 | Dell Inspiron 6400 Notebook
How to access Dlink Set up page ?
You must be in the same subnet as your device in order to configure it. If you are in the 192.168.1.0 subnet, change your IP address on your computer to the 192.168.0.0 subnet. Assign yourself a static in that subnet with the last octet between 1 and 254, but not 50. I use 192.168.0.250, but any unused IP address in that subnet will do. Once you are in the same subnet, you should be able to reach your AP. If you still can't get to the http interface, then go to plan B: Your access point came with a CD: D-Link AirPlus Xtreme G AP Manager that provides an alternate client interface. You can setup security and change the password, and SSID using the client interface software if your http connection does not do it for you. Once you change your IP to the 192.168.1.0 subnet (which I assume you intend as it sounds like that is your LAN subnet), give the AP the gateway address of your router's IP address, and change your IP address back to whatever it was on your computer.
Nov 29, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Wireless connection of 570s ap to zyxel wireless modem
did you get the cd with the router? I would run the cd. if not, what OS you use?
Nov 11, 2007 | Zyxel ZyAIR G-570S - Wireless access point...
My PC is not detecting the wireless Access Point
is your wireless adapter still ok? or is your wireless PC switch on? Try to check and then let me know.
Oct 11, 2007 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
What is WDS?
Wireless Distribution System (WDS) allows you to make a completely wireless infrastructure. Normally, the access points must be connected with a wire (LAN). These access points create cells allowing a wireless connection. The WDS feature allows the access points to be wirelessly connected. This feature is normally used in large, open areas where pulling a wire is restricted or not cost effective and in residential circumstances. If the structure utilizing an access point is too large to cover using one AP, a second AP would be used as a wireless repeater. The WDS has forwarding functionality for extending the range of an AP. By setting up an extended service set (ESS) between access points. Stations can intersect with any AP of this ESS and move between the coverage of both APs while the higher layer network connection remains intact.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
