Question about GE JVM1190 Microwave Oven
How may CFM are there in my GE JVM1190SYC02 Microwave?
Where do I look on the microwave for the CFM rating?
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
I need to replace my ge microwave zmc1095. what is a comparable microwave?
You can call GE customer service to see if they have "drop-in" replacement.
Otherwise, you can refer to your owner's manual for the specifications to compare to new ones.
Jan 15, 2013 | GE JVM1790SK Convection/Microwave Oven
Need a user manual for microwave model # GE JVM1640bb
Hi
Thanks for using FixYa. You can click on the link to download the user manual for your Microwave:
GE JVM1640bb User Manual
Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can i install an external blower outside to boost
Possibly so.
I'd first check to be sure the grease filter is clean, the duct work is not clogged, and the outside vent is not home to an animal's nest.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Jan 10, 2010 | GE JVM1190 Microwave Oven
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
How do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Microwave runs but no heat
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
Jan 10, 2009 | GE JVM1870 Microwave Oven
Ge microwave - uninstall from mounting plate
If you don't have the installation instructions, you can get them here.
They're very helpful when installing OR uninstalling.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burnt smell in microwave from burnt muffin in a GE microwave
Many solutions are found here:
http://www.google.com/search?hl=en&q=microwave+smell+OR+odor&btnG=Google+Search
Dec 06, 2007 | GE JES738 Microwave Oven
GE JVM1190 Microwave Oven Logo
49 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
