Question about Singer CE-100 Futura Computerized Sewing Machine
What does E7 mean on my computized sewing machine its beeping and won't sew
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
  • 240 Answers
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Posted on Jun 11, 2009
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here -
Posted on May 07, 2010
SOURCE: I am trying to make a buttonhole using the
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Posted on Nov 17, 2010
How do I reset my machine. I have Singer 7285q Patchwork. I got a E7 code, and now my machine will not do anything but beep. Help!
Search for:
Make Model error E7
sometimes the owner's manual shows error codes in the troubleshooting section.
Jun 30, 2017 | Singer Sewing Machines
What is the Singer sewing machine error code E7?
Hello, you didn't say what the model was? But here is a website to see what e7 means and download manual. Error Code E7 Singer 7258 Stylist Support
May 28, 2014 | Singer Sewing Co Machine Model 6199...
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
Error Code E7 on Singer 6180
E7 means the machine has 'had enough' and that error flashes to let you know it needs a break. I found that out by trial and error and after phoning Singer as well.
Nov 04, 2012 | Singer 7258 Sewing Machine
The machine says the presser foot is not down and it is so it won't sew
it could be a problem with the motherboard, the sewing machine needs to be checked
Oct 10, 2012 | White Sewing Sewing Machines
My Singer Brilliance 6180 flashes E7 there is nothing about it in the manual
try changing the needle
try using a different bobbin
if these suggestions don't help then I suggest you take the machine to be checked
May 17, 2012 | Singer Sewing Machines
I was free motion quilting, machine stopped. Beeps three times when I push foot pedal and won't sew
Check your buttonhole lever, left back of the machine. Pull it down and push it right up into the machine. Should solve your problem
Sep 06, 2011 | Singer Confidence 7467 Mechanical Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
