Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
LAMP COMES ON AND GOES OFF
I HAVE A HD50LPW42YX2 AND THE LAMP AND COLAR WEEL WILL COME ON FOR ABOUT TEC. AND GO OFF THEN AGAIN AND AGAIN AND NO SOUND
  • hvacman101 Jan 14, 2009
    okay put new lamp in still doing the same thing what now?
  • hvacman101 Jan 15, 2009
    yes i have the oem lamp from rca and a mounth ago i had a new ballest and light engine put in so the first thing i did was i shiped those parts back off and had tested and replaced so now i am back to squar one so i have installed the the new lamp
    Problem Solver:
Replace lamp
Posted on Jan 14, 2009
  • jaco4345 Jan 14, 2009
    samsung uses same lamp
  • jaco4345 Jan 15, 2009
    ok. make sure lamp door is closed and secured. then try again.if no help most likely you have a bad ballast. also make sure you are installing the right lamp being a new one. only had one prob. with the ballast
Image goes black and then returns shortly after
Many sets that use lamps do this right before the lamp fails--average life is 2000 hours or 2 years of normal use--if no blinking lights suspect the lamp first.
May 29, 2012 | Televison & Video
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Nov 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv picture and sound goes away for about one minute and then comes back. After another two - three minutes, the process starts over again, and again. Please help if possible, Thanks!!!
When the bulb goes off with the sound. The lamp is starting to fail andyou need to replace it. Wear gloves when replacing the lamp. UseXL-2400(part # F93087500) replacement lamp. For informationvisithttp://sonystyle.com/tv for US residents andhttp://sonystyle.ca/tv for Canada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Put the new lamp in its place. Mount it securely and take extra care not to touch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Disposethe used lamp properly. It contains mercury and disposalis regulated..Contact your local authorities for proper disposal.
Sep 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
PICTURE AND SOUND ON AND OFF
How old is this TV and have you replaced its Lamp during that time?
Symptoms shows your Sony KDF-E55A20 TV's lamp is weak and need to be replaced.
Lamp replacement procedure is written in its user manual and if you want online copy, let me know.
Aug 30, 2009 | Sony KDF-E55A20 55 in. LCD Television
SOUND AND PIC GOES OUT FOR 30 SECONDS, THEN PIC COMES BACK THEN SOUND. IS THIS THE LAMP OR THERMAL FUSE OR WHAT.
The lamp is going bad. If it was the thermal fuse it would not be intermittent. It is very common for some Sony sets like yours to do exactly what you describe when the lamp is going bad.
May 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
RCA hd50lpw42yx2 not working
There are 4 1000 mf. 35 V caps. on the AC IN pwb. (power supply) that are chronic fail items. After back is off, slide the chasis on the left side back toward you. Slide about 1/2 inch and it will lift out of track and then the chasis will be more accessible. The said caps are the tallest on the bd. and 2 are located side by side on the bottom front of the chassis. The other two are side by side about an 1 1/2 above the other 2. Most likely the top of the caps are pooched out. Replace all 4 whether they look bad or not. Problem solved
Jan 23, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
