Question about Xerox WorkCentre XL2130f Laser Printer
Workcentre XL2130f does not ready itslef sometimes
Had it a long time. Finally need to replace starter toner cartridge. Takes a long time to ready itself; sometimes need to re-poer up. Use only for photocopying rather than computer printing or fax. How can I ell if the drum needs replacing? Where can I get a user's manual? Is it worth servicing? Can I service it myself.
Lots of questions! Thanks.
Sylvia
    President:
  • 2,072 Answers
Normally when that happens the machine need a general cleaning. Also take the toner cartridge and shake it side to side to be sure there is enough ink where the density sensor is.
There is a light on the machine that will start flashing when the drum has about 500 pages left on it.
What you most likely have to do is take the toner cart and drum out, clean in that area well, Take a flashlamp and cloth dampened with some alcohol and clean any sensors , lamps you see. Also look to the left, you will see an opening about 1/4 of an inch high and 6 inches wide, That is your laser window. You want to take. most likely a Q-tip and clean that glasss inside that slot.
On thre right side door there also is a tranasfer wire, it is in an opening in a metal bracket that will need cleaned. Be cautious since it is a very thin wire. Dampen a q - tip with alcohol and gently wipe back and forth to clean that wire.
Then remove the screws around the glass, lift out the glass and clean the underside of the glass , lamp and mirrors.
The XD2130 is really a good machine, if you don't remember repalcing a drum on it, then you must not have a very high volume on it, I would even pay someone to clean it for you if you like.
Xerox doesn't service it any longer, but parts and reputable people still service those on a daily basis. Its a good machine,
Posted on Jan 13, 2009
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
Toner light needs to be reset, will not go off
reset your toner cartridge chip . than cartridge replica
Jun 24, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre XD125F- need manual
You can get the spec sheet and the user's guide as PDFs here:
http://www.support.xerox.com/go/results.asp?prodID=XD125f&Xlang=en_US&Xcntry=USA&Xtype=docs&prodName=WorkCentre%20XD125f%20Digital%20Copier%20-%20Laser%20Printer
The spec sheet has the toner cartridge and drum cartridge part numbers (listed as Supplies)
Toner Cartridge 6R914;
Drum Cartridge 13R551
When copier has printed about 18,000 pages the J2 drum cartridge light will come on. The unit will print about another 1,000 pages before the unit stops working until the drum cartridge is replaced.
I hope this helps.
Apr 14, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Diagram of how to remove a exploded toner
Compressed air and a toner vac. You might need to remove the platen glass and clean up under there as well.
Jul 11, 2009 | Xerox WorkCentre XL2130f Laser Printer
Unknown error 009-391
Remove Cyan Cartridge. Trun Off the Machine.
Now Insert Cartridge, make it properly inserted.
Trun On the Machine And The Error Is Gone......
Try It
May 20, 2009 | Xerox Office Equipment & Supplies
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox workcentre Xl2130f copier printer error j1
that is the message for low or out of toner. What you are doing by tapping it is just lostening the reemaining ink in the cartridge. If the cartridge is new, have it replaced where ever you purchased it because most likely its defective.
Oct 02, 2008 | Xerox WorkCentre XD120f Copier
ERROR MSG CH
A CH code means the toner cartridge is not being sensed.
Could just be not seated properly. Open the front and remove and reseat the toner cartridge.
It may be empty also.
Aug 24, 2008 | Xerox WorkCentre XL2130f Laser Printer
Toner
Push up on the release latch on the Right Side Cover to open the cover
  1. CAUTION: Ensure the side cover is always open before opening the front cover.
  2. Open the Front Door.
    Turn the orange Toner locking lever up to unlock the Toner Cartridge.
    Pull the Toner Cartridge out of the machine.
  3. Remove the new Toner Cartridge from the box. Save the box and the packaging for storing the old cartridge.
  4. Gently shake the new cartridge horizontally 4 or 5 times to loosen the toner. Be careful of any Toner spill.
    NOTE: Shaking the cartridge will ensure maximum copies per cartridge.
  5. Slide the new cartridge into the machine until it locks in place
  6. Turn the Toner locking lever down until it locks in place.
    IF it is not sliding in. remove the cartridge and on the back of it, there is a round drive you may have to spin a quarter turn and reinsert. Sometimes that doesnt line up
May 19, 2008 | Xerox FAXCENTRE 2218 18PPM FAX
Xerox work centre xl2130f developer
It goes in with the toner. The developer and toner mix in the cartridge. Empty the old out and put it in with the toner.
Good luck.
Feb 07, 2008 | Xerox WorkCentre XL2130f Laser Printer
Xerox WorkCentre XL2130f Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
