Question about JVC Televison & Video
What's PBC and why won't machine initialize disk -- area won't light up to allow selection -- nothing can be selected above PBC and it doesn't matter whether it's checked on or off
When I place a blank dvd in the recorder, it should initialize the disc. Instead, "read" appears in the display, followed by the whirring of the disk, a coupleof clicks and then the disc door opens and it shuts off. When I use the set up menu, under disc, "initialize," "finalize,' "disc label," and "disc protect" do not light up and, therefore cannot be selected. However, when I selct PBC, the aforementioned areas DO light up, but still cannot be selected because as soon as the cursor is moved from PBC, they go dim again. . . I cannot record because the machine automatically tries to read a disc that has not been initialized. I tried initializing the disc using my computer . . . nothing.
5 Suggested Answers
SOURCE: DVD recording problem
i thing u r read write head is gon
Posted on Apr 01, 2008
pincer
  • 377 Answers
SOURCE: Initializing DVD
If you know you're using a readable disc, clearly the drive is the source of the problem. It's possible that the drive's laser has become dirty to the point that it can't read the disc. Open the drive's caddy and spray into the drive with compressed air. The blast of air should blow away any dust buildup over the laser. Pop a disc into the drive and try to read it again.
Posted on Apr 14, 2008
SOURCE: Disk Initialize
If it's a DVD recorder, make sure you are using compatible DVD-R media. Check in the user's manual if it supports DVD+R or DVD-R.
Posted on May 05, 2008
Junoon007
  • 1011 Answers
SOURCE: I am trying to record
click this link for connections to "how to setup"
Thanks
good luck
Posted on Dec 10, 2008
Singer featherweight fw75
You may need to override the current selection by selecting next design , then get back to your original design selection again. And this should work. However if still not working, just switch off your machine and after awhile put it on again. Hope this will help.
Jul 24, 2013 | Sewing Machines
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
My emachines e350 won`t turn on it alweys says No bootable device--Please restart systam and I do that and it says it again
Check that you have not left a non-bootable CD, diskette, or DVD in the drives of your PC, nor have any USB devices plugged in that the system might be looking to try to boot from.
If the above check is clear, then go into the BIOS settings and check that your internal hard disk drive is set as the first boot device or is ahead of any other disk drives you may have installed.
You cannot connect computers to each other by just using a standard USB cable - it doesn't work that way.
If you still cannot boot from your internal hard drive, then you should consider downloading a copy of Hiren's Boot CD (which is a CD .ISO image) then burn this to a real CD and try booting from that media - you may have to select the CD as a boot device in your BIOS or if you get a boot options menu.
If you can boot the Hiren's CD ok, then your internal hard disk may have failed - you can test this with the DOS Programs of the Hiren's CD by selecting Hard Disk tools then selecting HDAT2 which will try to find any installed hard disks then allow you to test these and repair problems if possible.
Jan 01, 2012 | Computers & Internet
What's your problem?my ipod is asking for password to connect to wi-fi, what is my password? How do I find out what my password is?
Go to the Belkin setup page (http://192.168.2.1/index.asp) and select Wireless 1) Wi-Fi Protected Setup(WPS)
Select
2) Push Button Configuration (PBC) Method Push and hold PBC button on your Router for 3 seconds or click "Start PBC". Then start PBC on the device you want to connect to the Router within 2 minutes.
Oct 01, 2011 | Belkin Basic Wireless Router
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
ACER ASPIRE 3750G 13.3", reformat.
when you turn the unit on hit Alt+F10. This will access the acer recovery partition from which you can restore. This is provided you didn't replace the Hard drive or wiped the drive yourself
Aug 02, 2011 | Acer Computers & Internet
La Cie USB hard dirve its lighting intermittently red and yelow and the computer not recognized
Plug your usb drive into your computer. Then right click on my computer and select manage. Select disk management in the left pane. scroll down to look for your external drive in the bottom pane. You might need to initialize the disk by right clicking the gray area to the left of your disk on the bottom pane. If its already initialized you should be able to right click the disk just to the right of where you just clicked and select format, making sure to assign a drive letter and do a quick format of ntfs through the wizard that pops up. If the drive is labeled GPT protected you'll have to convert the disk to MBR by using the diskpart command. Go to start then run and type cmd and hit enter to bring up the command prompt.
  1. Type diskpart and hit enter
  2. Type list disk and hit enter and find your disk in the output
  3. Type select followed by your disk's number, for example "select disk 1"
  4. Type clean and hit enter
  5. Close the command prompt and now you should be able to initialize and format your disk.
Mar 04, 2011 | LaCie F.A. Porsche (301177) Hard Drive
Philips DVD Player DVP 3026 set for Region 5 - Unlock code
1) Open the tray
2) Press SETUP on the remote.
3) Navigate to PREFERENCE menu
4) Go to PBC
5) Get in inside PBC menu so that ON is highlighted with yellow color
6) Key in 138931 and a menu will appear asking you to select region code.
7) Select REGION 0.
Jun 17, 2008 | Televison & Video
Disk Initialize
May 05, 2008 | GoVideo Go Video DVD/VCR Combo
Dubbing rom hdd to dvd
All you have to do is select dvd on the remote (at the top). Then it should do it automatically. If it doesn't, go to menu, then setup, disk, format. That does the job.
Nov 17, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
