Question about Acer Aspire 9410 Notebook
How do I remove keyboard Acer 9410 and replace with new one?
Have to replace my keyboard and need to know how to get current one off so I can put my new one on.
How do I get it off safely
    Problem Solver:
  • 9 Answers
Start by turning the laptop off and removing the battery so that you don't accidentally restart it.
As posted eleswere, the 9410 has clips holding it in to the top of the laptop.On some units there are 4 of these clips, not three. On a new unit you can push clips back with very little effort and lift the keyboard up alog the edge closest to the screen with very little effort by gently putting something thin like the edge of a rasier knife just underneath the edge of the keyboard. Don't worry, as you'll see when you get it out, there is nothing to cut there and there are no electronics to damage, even a 1/4" in under the keyboard.
On some units though, you may be replacing the keyboard because something has been splilled into it. In that case, the little clips may not move as freely, just give them a good push and they should break any little seal that has formed from dry sugar or other things in the drink. The next challenge will be the keyboard. If you look at the bottom of the new keyboard you will see it has a large flat surface with a flat ribbon connector on it. When it's installed, this flat surface is pretty much right up against a similar flat surface inside the laptop. If a spilled drink has been allowed to dry in there you will probably find that the two surfaces are glued together by the sugars and that pulling up on the keyboard just doesn't feel right. At this point you need to know that there are no screws or anything else holding it in place, it's just glued in by the drink. In this case you will need to work from a corner ( R or L, doesn't matter) and really pry up the corner. You will probably bend and damage the old keyboard a bit doing this. Once you get a corner up. Use the blunt end of a table knife or something similar to work your way along the edge of the keyboard nearest the screen until the entire leading edge is free. You can work in an inch or two, you won't hurt anything. Once you have the leading edge free you'll need to peel the keyboard away, probably by working first around the outer edges at the sides and towards the front of the unit to break the seal caused by the dried up drink. If you look at the new keyboard you'll see that the ribbon cable fastens in somewhere near the center. Once you've freed up the keyboard, the ribbon cable will pull loose from its connector by simply pulling it flat towards the front of the laptop. Try not to pull up as much as possible, a little won't hurt and is almost impossible to avoid but keep it as flat as possible. Once you have the flat cable unplugged the old keyboard will simply pull away from the unit. You can clean the area where they keyboard sits wth a vacuum and work on any sticky deposits with a soft cloth or Q-Tip and, if you have it, a little bit of alchohol. Even water is OK on a damp cloth but it doesn't evaporate as quickly so rub it dry when you are done.
On the laptop side you will see the connector that you will be sliding the flat cable back into. On most laptops the cable locks into place a little better with a mechinsm on the side of the connector that you can slide forward close to an 1/8th on an inch ( 2 to 3 mm). This will make it much easier to slide the flat cable in from the keyboard. If possible you cna make getting the old keyboard out a little easier by releasing this before you unplug the cable. Once you have the cable from the new keyboard inserted, push the mechism toward the screen on the two sides to help lock the flat cable in place. Then, lay the tabs along the front of the keyboard into the slots they fit into toward the front of the laptop (nearest the space bar) and gently push the keyboard in place down past the three or four retaining clips that hold it in place on the laptop along the screen end of the keyboard.
Replace the battery, turn the laptop on and your new keyboard should be working. If it isn't working you should reverse the procedure to make sure the flat cable is plugged in. If it is plugged iona nd the keyboard still isn't working you hav esomething a little more serious wrong and may want to send the unit in for service. Tehre aren't really any more user-serviceable parts that would affect the operation of the keyboard.
Posted on Dec 13, 2009
Look across the top of the keyboard and you will see three small clips or tines that hold the keyboard in place. With a tiny screwdriver or knife point, push each of the clips toward the screen - doing so will release the top of the keyboard. Once released, rotate the keyboard up and move it towards the screen - this will release the bottom portion of the keyboard. Under the keyboard you will see the ribbon cable that connects the keyboard to the computer base - pull the ribbon cable to the rear towards you to release it, and the keyboard and ribbon cable are free of the computer. If the keyboard is damaged or if any of the keys are not working, you can get a brand new keyboard for less than $30
Posted on Feb 06, 2009
  • 903 Answers
Go here http://rapidshare.com/files/38725771/SG_AS_9420_9410_7110_TM_5620_5610_5110_Merom_BOOK.pdf.html
it is a long link but you will be able to download the service manual which has pictures and instructions on how to remove the keyboard,
Do the following,
CLick on the link, when the link comes up click on Free user, you will then have to wait for 30 seconds, then click on the blue circle that says download, select save it, and choose where you want to save the manual on your pc, it will be in pdf format so you can open and read it at your own leisure once it has been downloaded. Depending on your internet speed it should take between 5-10 minutes to download.
I hope this helps
Posted on Jan 13, 2009
I bought an Acer Aspire 9410-4933 from a neighbor. He removed the 160GB hard drive becausehe did not want his files exposed. I installed 2 dual channel RAM and a 320GB HD from an Acer store. I am having a...
I'm repairing laptops for eight years and this problem has something to do either with the HDD or your RAM. If you have two modules of RAM try either of the two if it will pose the same problem. If not definitely the culprit is your HDD. It doesn't matter if it is brand new that it will work perfectly. They are transported and we don't know how they were handled.
May 27, 2011 | Acer ASPIRE 9410-4933 COMPATIBLE LAPTOP...
I am looking for travelmate c110 keynoard to replace the current keyboard.
http://www.cdsparts.com/p-37-new-acer-travelmate-c110-series-keyboard-kbt2707001.aspx
This is a place to buy a new one. Let me know if you need any more help. Hope this helps.
Mar 07, 2011 | Acer TravelMate C110 Tablet PC
How do I remove the keyboard for the Acer Aspire 9410
You should see a plastic piece that runs along the top of the computer just above the keyboard. This snaps in place and can be pried up. Be careful, though. There may be a screw under the computer that has to be removed first.
Look on the back of the computer. There may be two screws in the hinge covers. If so, remove them.
Once the plastic piece is off, you will find screws (probably 3 or 4) at the top of the keyboard. Unscrew them and lift the top of the keyboard up. Carefully disconnect the ribbon cable toward the bottom and you're there.
Nov 19, 2009 | Acer Aspire 9410 Notebook
Bios of laptop Acer Aspirinhe 9410 (reset the bios)
Hi...
To reset the bios you need to open your laptop you can see there a jumper which is there is a small name (CLRSCR means clear cmos)beside the jumper you need to get it and turn on your laptop with in 5 seconds then turn it off, after that you reinsert the jumper, then turn on your computer and see if there is a bios password. "good luck"
Regards
PCmania
Jul 14, 2009 | Acer Aspire 9410-4317 Notebook
Setup password lost in an Acer Aspire 9410 laptop
The best way to this is to reset the cmos on the motherboard of the Laptop. This will reset the bios password.
To do this unplug all power from the unit and remove the battery. Remove the cover from the laptop so the motherbard is exposed. Look for the cmos battery (about the size of a nickel) and remove the battery for about 30 mins and then replace. Reassemble your laptop and you should be good to go.
Feb 24, 2009 | Acer Aspire 9410-4317 Notebook
Acer aspire 3000
HERE is a link to the repair guide for the Acer Aspire 9410. With this, you should be able to find the correct method or removing the original keyboard and replacing it. If you have a replacement from Acer, you should have been given instructions on how to replace it manually.
Dec 20, 2008 | Acer Aspire 9410 Notebook
Hi. I spilled coffee on keyboard ACER 9410 laptop. Now a couple of the keys do not work and screen jumps when I hit some keys on right side of keyboard. Can I replace the keyboard to fix the problem and...
I did the same thing. Here's what I did:
Took whole thing apart. Cleaned any coffee with q-tips dipped in water / paper towels. Removed the keyboard. Ran it through the dishwasher with no soap in it and heated dryer off of course.
I let it dry for a day and was bummed that now the whole keyboard stopped working. Well then 4 days later to my surprise / delight.. the whole thing started working again. New keyboards on ebay were also very reasonable. But mine still works perfectly after the dishwasher cleaning.
Sep 11, 2008 | Acer Computers & Internet
Acer Travelmate 7510 series keyboard removal
see it this applies to your model
http://www.kriyayoga.com/how_to/how_to_replace_hidden_ram_slot.html
Nov 22, 2007 | Acer NSK8458AN Keyboard
How to take an acer apire 9410-2028
You'll have to remove the mother board to fix this. Basically, remove the keyboard & touchpad. You will see the mother board at that time. Remove whatever else is necessary to get down to the mother board. Hint! Keep track of what screw comes out of what hole. You'll need to know that for reassembly.
Ron-
Nov 11, 2007 | Compaq Presario Notebook
Acer Aspire 9410 Notebook Logo
2,297 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
