Question about Dryers
What color wire do i disconnect the fan on c22.2no.190 ceiling fan
2 Suggested Answers
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
Wiring code for ceiling fan
These fans do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 30, 2010 | Hampton Bay 04893 Ceiling Fan
Wiring for ceiling light
The wiring for a ceiling fan is usually pretty simple. The wires are connected color for color. that is black/lack, white/white , green to green or to the mounting bracket .. this color connection would also apply to the connections at the power source. If you have a light kit on the fan and two switches on the wall , then the red wire from the switch connects to the other wire on the fan, usually blue, if there is only one switch, or you are wiring it direct, then the black and blue wire both connect to the black power wire.
Mar 21, 2010 | Hampton Bay 24002 Ceiling Fan
Need instructions to fix ceiling fan - Hampton Bay 55295 + remote
if you tell me what colors of the wires you have on the fan y what colors of the wires on the ceiling may be can help you here is my E-mail: mhernandez781@hotmail.com.
have nice day
Jul 15, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Replacing old fan with Hunter 20763.
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
Jan 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Cieling fan install
on the side with blue black and white the go color for color to the motor wires.
the side with red and white:
red goes to hot in ceiling
white goes to neutral in ceiling.
Nov 09, 2008 | Aloha Housewares (93645) Ceiling Fan
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Dryers Logo
114 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
