Question about MSI 865G NEO2-LS (MS-6728) Motherboard
What's your problem?MSI 865PE Neo2-FIS2R (MS-6728 v.1) i865PE Based Mainboard
  • 231 Answers
SOURCE: cannot install windows
Hi, check what amount of RAM you have. XP can be loaded at 28Mgb of RAM but is more succesful at 256Mgb which is the recomended minimum. The ideal amount of RAM for XP is 512Mgb and I believe you can never have too much RAM.
Regards mistyman
Posted on Feb 19, 2008
  • 3 Answers
SOURCE: bios may be flash, blackout total
cheak the mislaniass canccter
Posted on Sep 23, 2008
rajeshmb
  • 38 Answers
SOURCE: is MSI 865PE Neo2-V motherboard support graphic work?
Most of the applications that you have specified above use high amount of the memory. If you are using vista this makes it even worse. Get another 512MB RAM and install it in the next DIMM slot and it will be alright. 512MB Ram should cost you around 500-700Rs.
Posted on Nov 13, 2008
SOURCE: i need driver usb 2.0 for my mother board MSI
Windows should find and install the latest themselves, try letting it do a driver search online to find the latest.
Otherwise get from the manufacturer. Try here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=600
The chipset drivers should do it.
Posted on Feb 04, 2010
Testimonial: "many thanks for your solutions.. regards, abet"
bronk50
  • 27725 Answers
SOURCE: Hello, My 865PE Neo2 (MS 6728
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Posted on May 28, 2011
Specs on this cpu process
MicroStar International (Inc) Support > 865PE Neo2-P Platinum Edition (MSI MS-6728) Main Support page,
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html
Click on Specification
(Overview / Specification / Download / Support / etc)
CPU (Processor) Support;
1) Intel Pentium 4 processors that have;
A) Use a Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
B) Northwood Core, or Prescott Core
C) Front Side Bus (FSB) of 400MegaHertz (400MHz) for Intel Pentium 4 processors that are based on the Northwood Core.
D) FSB support of either 533MHz, or 800MHz, for Intel Pentium 4 processors based on the Prescott Core.
Processors that have an 800MHz FSB can be used, that have UP TO a 3.6GHz frequency rate. ('Speed')
Indication that higher 'speeds' can be supported. (Overclocking?)
Now let's look at Intel Pentium 4 processors, that are based on the Northwood Core, and fit a Socket 478 processor socket,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Front Side Bus = FSB
The M/Ts listing means MegaTransfers per Second.
Believed to be a more accurate method of stating the FSB, than MHz.
MegaHertz
Mega = 1 Million
Hertz stands for Cycles per Second. Was named after a man with the last name Hertz.
Example; 400MHz = 400 Million Cycles per Second )
Intel Pentium 4 processors based on the Prescott Core, and utilizing the Socket 478 processor socket,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
sSpec Number will be on the processor, as well as the Part Number.
http://www.cpu-world.com/CPUs/Pentium_4/index.html
Scroll down for photos.
CPU support can be attested to looking at the specs for the motherboard chipset, on your motherboard.
The motherboard chipset is an Intel 865PE chipset.
Intel 82865PE northbridge chip, and an Intel ICH5 southbridge chip.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
Scroll down to 865PE in the left column.
The part number on the Intel ICH5 southbridge chip, is Intel 82801EB,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Southbridge_8xx_chipsets
The Northbridge chip of the motherboard chipset, handles the Faster capabilities of a computer.
Processor (CPU), Ram Memory, and HIGH-speed graphics.
HIGH-speed graphics is the AGP technology, or PCI Express technology.
Using a graphics card in a PCI slot, or using Integrated Graphics; is NOT high-speed graphics,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Slower capabilities of a computer are handled by the Southbridge chip.
If this is a question of what CPU is on your motherboard at present, and the motherboard is in a working computer, suggest use the free tiny program CPU-Z from CPUID.com,
http://www.cpuid.com/softwares/cpu-z.html
Need to know how to download, install, and use CPU-Z, post back in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Micro Scooter MS-6728 Micro Microstar Msi...
Perescott 533 driver
Hello the drivers can be downloaded here:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=All
Please select your windows system.
If i am wrong by the mainboard model, enter the ms xxxx number here:
http://www.msi.com/service/download/
The ms number is located here:
Good luck
Oct 05, 2012 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Please help! driver needed MS-6728 ver2
http://www.msi.com/product/mb/865G-Neo2-S--LS.html#/?div=Driver&os=Win7%2032
May 01, 2011 | MSI 865G NEO2-LS (MS-6728) Motherboard
Where can I get driver for this motherboard?
you can get it here. Go to the downloads section and download the drivers you need.
Thanks for using Fixya.
Mar 31, 2011 | MSI 865PE Neo2-S (MS-6728-010) Motherboard
Ms 6728 Neo2 P
MSI 865PE Neo2-P (MS-6728)
Check out this link @ http://www.msi.com/service/search/?kw=MS-6728&type=product
Hope it helps.
Mar 02, 2011 | Computers & Internet
My PC with 865PE Neo2-FIS2R doesn't boot on SATA HDD... It actually runs windows server 2000. but after an unexpected power shutdown... the pc always boot on Managed PC Boot... upon checking on the Boot...
Hi Good day!! well i think your board didn't detect your HDD for some reason:
1. unexpected shutdown
2. cable not properly connect in HDD to motherboard
3. HDD have been damage because of improper shutdown.
here are the step to detect your HDD
1.pull out your cable from the HDD and then re-insert it make sure it its inserted properly.
2.go to CMOS and then in the "MAIN menu" check the primary master, primary slave, etc. in the primary master your HDD should be detect there. if not enter your primary master for auto detecting.
if nothing happens and still not detected you must replace the cable of your HDD.
Pls. Reply to help you more
Regards
JR
Oct 07, 2010 | MSI 865PE Neo2-FIS2R (MS-6728-030)...
What is the max ram Ican run with a 865pe neo2-p motherboard and
Main Memory
�� Supports bandwidth up to 3.2 GB/s (DDR 400) for single-channel mode and 6.
4GB/s (DDR 400) for dual-channel mode (for 865PE only).
�� Supports two (for 848P) / three (for 865PE) unbuffered DIMM of 2.5 Volt DDR
SDRAM
�� Supports up to 2GB (for 848P) / 3GB (for 865PE) memory size without ECC.
�� Supports only x8, x16 DDR devices.
�� Supports Dual-channel (for 865PE only) DDR 266/333/400 (based on DIMM 1.3).
(For the updated supporting memory modules, please visit http://www.msi.com.tw/
program/products/mainboard/mbd/pro_mbd_trp_list.php.)
Regards.
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Msi 865pe neo2-p (ms-6728)
well if thats so...theres only way and hope you can rebuild it...download from the official msi site www.msi.com.tw the bios properly for the board,make a bootable cd and under DOS mode try to rewrite it.
for now theres no bios in your board...
but I must say you...It is a huge chance that you did a severe damage to the board and may not be recovered..
however try the bios  like I said...
keep me up to date..I  worked a lot with MSI boards..I really want to know how you do it..
bye
Feb 09, 2008 | MSI /865PE NEO2 PLATINUM ED. Motherboard
MSI 865G NEO2-LS (MS-6728) Motherboard Logo
22 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
