SOURCE: Condensation
On most watches, if you get condensation within the face, means that there is a small crack on the glass/plastic covering. Some watches you can take apart from the back and pull out the workings and replace this casing, on others, you have to take it to the jewelers to have it replaced. Depending on how much you paid for the watch, you are better off buying a whole new one.
SOURCE: I have the Fossil FS-4154,
Did you put the protective cover back over the battery? sounds like a grounding problem.
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
SOURCE: can't find the watch band for fossil arkitekt fs
I have the same watch Fossil FS-4127 and I too can't find a replacement band. Appears to be planned obsolesence by Fossil. This FixYa site is almost as bad as Fossil, which is all advertisements and no answers whatsoever.
SOURCE: I have a Fossil Arkitekt
You will have to remove the back off the watch (cant take off the face). You MIGHT be able to access the hand from there, but you may have to adjust some of the watch inner movement and that will be risky but you can try.
Goood luck
