Question about Carrier Heating & Cooling
Error 87 on carrier infinity condensor
Carrier condensor infinity
  • 38 Answers
SOURCE: Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Posted on May 07, 2009
  • 15 Answers
SOURCE: carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Posted on Jul 08, 2009
SOURCE: Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Posted on Jan 10, 2010
kingbrizzle
  • 407 Answers
SOURCE: I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Posted on Feb 03, 2010
Testimonial: "Great Solution. I spoke with the installer of the unit this morning and went through everyting you mentioned. It was as simple as a loose connection."
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
I have carrier infinity heat unit split system now my thermostat keeps saying comm error
Unplug the AC unit for 5 minutes to see if it will reset and clear the communication error.
Nov 18, 2016 | Carrier Heating & Cooling
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
A Carrier mod # 24ANA760A300 Infinity with an error code #72 high stage thermal cutout, What causes this?
if it's a thermal cutout that's mounted on the circuit board you may have to replace the whole board. I don't have the carrier error codes at hand. But a "thermal cutout" is normally found on the compressor. One advantage of the old (before digital) systems is that the controls were all separate. So you could replace a bad high pressure switch or contactor. Without having to replace a expensive circuit board that held most of the controls.
Not to mention being easy to damage by power surges and lightning
Jul 11, 2012 | Carrier Heating & Cooling
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier infinity control SYSTXCCUID01-B sensor communication erro
Jul 07, 2009 | Heating & Cooling
The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
May 21, 2009 | Heating & Cooling
I have carrier infinity 18 central air and worked good for one year and second year summer season its out of purion gas and we had an authorized person to recharge with purion gas and worked for a few days...
Carrier carries a 5 yr parts warranty.I'm not a big Carrier guy but the are not an inferior product from what I've seen.I'd contact another company that is a Carrier dealer for a second opinion.
Aug 05, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
