Question about Sony KDF-E42A10 42 in. LCD Television
Sony e42a10 s-video sound no picture
Sony e42a10 s-video has sound no picture
  • 6 more comments
  • moondoggy1 Jan 13, 2009
    Checked s-video cable with ohm meter no problem. Connected laptop with s-video cable and it worked fine next time connecting all i get is sound no picture
    There is only 1 s-video input on the tv
    Thanks I am going to try a s-video to composite
  • moondoggy1 Jan 14, 2009
    Thanks for the info. I also found that site but I didn.t have to get the cable. Turns out that same site explained how to turn the s- port on that was the problem. The link that explains it is on the same page as the cable you suggested.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    This cable might help you.
    I'm sure its either s-video cable or connector, you can use composite video (yellow) as alternative.
    Try another S-Video input in TV as this particular s-video connector can be bad.
    Check S-Video cable. It can be broken or not hooked properly on either ends.
    Champion:
  • 240 Answers
Replace B block Assy.
you can call andres electronics at 1800 289 0300
give them model number and ask for the B block assy.
for more help see my site allrepair dot us
Posted on Jan 13, 2009
Missing random pixels from all inputs, menus are all good. Sony KDF-E42A10. What board would be the culprit.
as you tell its look like video board problem for confirmation please send me picture of your problem so i confirm you.
Oct 21, 2010 | Sony KDF-E42A10 42 in. LCD Television
My Sony KDF-E42A10 turns on and then after a min the picture and sound will go away and the light "Power/Standby" will flash green. after a little bit the TV sound and video will come back on for a...
It is symptom of weak lamp that reaches at end of its working life, replace lamp in tv to fix the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 31, 2010 | Sony KDF-E42A10 42 in. LCD Television
In regards to my Sony KDF-E42A10 I heard a pop and the picture and sound went out. The green light just blinks and there is no picture or sound. What could be the problem?
I disagree with info given by expert.
Pop sound would be broken lamp in tv, take out lamp from tv and check it, replace it if found broken.
Usually lamp got broken at end of its working life span.
Aug 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
No Picture on Screen
They might be a problem with the video section(video card)this is where picture is generated and need to be checked there is a possibilty of a chip getting or has a leak .
The bulb gets voltage from this card so pls check it .
GOOD LUCK DUDE.
Nov 24, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 video problems
Your Sony TV probably is suffering from old age.
Jul 11, 2017 | Televison & Video
Sony LCD KDF-E42A10 Television
Please count flashes on Sony KDF-E42A10 tv and let me know.
Its error signal and shows problem with particular area in your tv.
Sep 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10
replace the lamp and you will most likely be good to go.
Mar 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10
correct, no video source, whether it be on a video input or cable, still the colored lines
Jan 15, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42 in. LCD Television Logo
96 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
