Infinity condenser
SOURCE: Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
SOURCE: carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
SOURCE: Sensor Error on Thermostat for Carrier Infinity System
Either miswired, or incompatible components, or outdoor thermistor isnt installed or is bad
an easy fix if onsite
SOURCE: I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Testimonial: "Great Solution. I spoke with the installer of the unit this morning and went through everyting you mentioned. It was as simple as a loose connection."
SOURCE: I have a system malfunction in my carrier infinity
start by going to service in the advanced setup to see fault
