Question about Sharp 32U-S610 32" TV
Volume button on tv doesnt work no remote
The raise volume and change channel up work but neither the lower volume or channel down buttons work... they click but nothing happens
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
Posted on Dec 12, 2012
SOURCE: Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Posted on Sep 22, 2007
  • 5 Answers
SOURCE: Channel memory reset
Bryan,
Usually the menu can be accessed from the buttons on the console, sometimes by pressing a "menu" button but other times by pressing both Volume or Channel (+ AND -, UP AND DOWN) buttons simultaneously. Menu levels are usually selected with one or the other of Volume or Channel, and toggles/selections with whichever doesn't do the levels.
Posted on Nov 09, 2007
  • 52 Answers
SOURCE: won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Posted on Mar 07, 2008
  • 146 Answers
SOURCE: problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Posted on Nov 10, 2008
bshldn
  • 736 Answers
SOURCE: Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
Posted on May 05, 2010
Does anyone know what's going on?
Unfortunately the bandwidths of remotes often crossover. You can put tape over the ir sensor on the ac.
May 21, 2012 | Haier Heating & Cooling
Remote fall on floor and now it is stuck on one channel and I can not turn off the TV or change a channel or lower the volume
Hi, well you can do everything from the axtual TV itself, have a look on the TV you will find a setof buttons/keys. these allow you to controll almost everything that the remote can do.
here you can change channel change volume etc.
The buttons usually there are 6- 7 marked On/Off, Channel up/down, Volume Up/Down, Enter/OK & Menu. Now pressing these will bring up the onscreen display and you can adjust what you wish.
Now with the remote, it's probably best to obtain a new one..
Sometimes disassembly may fix it, but it sounds like it has a bad problem.
To ensure it doesn't interfere remove the batteries.
Aug 19, 2010 | Televison & Video
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Nov 18, 2009 | Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
No factory remote i can't acess to the menu system
Most televisions and monitors have a menu button next to the power, volume, and channel buttons on the face, top, or side of the set. It can be a pain but you can usually press the menu button to bring the menu up and then select and change settings by pressing menu again to choose a setting and using the channel and/or volume up and down buttons to raise or lower the setting. The exact function varies based on the set so you may need to fiddle around a bit. Unfortunately some sets do require the remote to perform some functions.
Jul 02, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
Aug 07, 2008 | Samsung TXG2548 TV
RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Mar 13, 2008 | RCA RCR460 Remote Control
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Sharp 32U-S610 32" TV Logo
54 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
