Question about HP Compaq Presario v3000z Notebook
Laptop wireless won't connect to internet signal is excellant
Signal is saying excellant other pc working fine just won't connect i've tried repair but nothing.please help!!!
  • 4 more comments
  • lisa991981 Jan 13, 2009
    Hi im using internet explorer im not very good at this i tried command prompt what should i do next?thanks
  • lisa991981 Jan 15, 2009
    Yes its been working fine just the last while it won't connect,,the signal always says very good but the page just won't come up,the pc is a network cable.
    Not sure what an ssid is??
  • Chris Hingee
    Chris Hingee May 11, 2010
    What make and model is your wireless card?
    When you configured your wireless router, did you setup the router with encryption, if so was it WEP or WAP and did you enter the WEP or WAP encryption key into your wireless card using the wireless card's utility setup?
    Also did you change any of the default settings on the router?
    You should have change at least the default Admin password.
    If not, someone could have hacked into your router and changed your settings and or steal of your Internet Access.
  • Chris Hingee
    Has this laptop been working and connected to the internet before?
    Your other PC, is it connected to the Internet by a network cable or by a wireless connection?
    When you click on your wireless utility, can you see your wireless router and its SSID?
  • Shawn McGuire
    Shawn McGuire May 11, 2010
    In internet explorer click on tools then internet options, then click on the connections tab, then select LAN settings. Make sure that you have Automatically detect settings and see if that helps. If that doesn't work then try the command prompt again and type: Ping google.com
    If that works then it's the browser settings not your internet. Keep me posted
  • Shawn McGuire
    Click on start then run, type in cmd and hit enter.In the command prompt type ipconfig /all After that post what it says here and what browser you are using. I've dealt with similar problems but need a little more information. Thanks.
How do i get internet on my laptop from my pc not using a cable?
Posted on Apr 10, 2009
  • 520 Answers
Double click on ur wireless icon in sys tray.wireless network status is shown ...click properties...in wireless properties scroll to internet protocol ...in internet protocol properties choose obtain ip address auto and choose obtain dns auto click ok..try to connect if no connection use repair ...you will see aquiring ip please wait.
Posted on Jan 26, 2009
  • 218 Answers
I believe your problem is described in this article by HP. Read it and then call the HP number listed. If they agree that it's one of the problems in the article, then they will replace the motherboard free.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Posted on Feb 12, 2009
Toshiba satellite l25-s119 internet won't work.
Wired or Wireless? Try a Ethernet Cable to verify the ISP is sending a signal. Try another broswer.
May 04, 2013 | Computers & Internet
Dell inspiron 1525 says limited or no connectivity
Could be an issue with the router. Try resetting the router.
Mar 08, 2017 | Dell Inspiron 1525 Laptop
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
I have a Virgin modem & d link DIR 615 router. I am connected to my desktop via ethernet cable which connects to the internet ok & works fine. I wish to connect my wife & son's laptops...
Hi
while your computer connect to the internet so the connection is good ..
but in other laptops please do that change IP mode to the DHCP Mode or give IP in the same network
try to click repair
Apr 25, 2011 | D-Link DIR-655 Wireless Router
I have just installed netgear wireless ADSL2 modem router. The wireless works fine on one laptop and iphone but even though my other laptop says it is connected and the signal strength is excellent, I...
is your laptop getting a DHCP address? is it getting the correct DNS? Do this by going to control panel. Network Connections. Right click on the wireless connection. choose properties. double click oo TCP/IP. set to DHCP
Also check your Internet Explorer settings to see if it is using a proxy server under internet options. connection settings. If it is on or set to a proxy server. turn it off.
Mar 06, 2011 | NetGear DG834G 54 Mbps 802.11g Wireless...
I can't get internet connection even though it says my connection strength is "excellent."
The netbook is working fine. The WiFi connection or SPID may require you to login as in it is a protected signal. The "Excellent" means that you are receiving an excellent signal from the router. What you want is internet access which is upstream of that. Try a different SPID or connection.
Nov 25, 2010 | Sylvania G-Netbook
Unable to connect to internet
Is the router proper connected to the modem?
Apr 20, 2010 | NetGear DG834G 802.11G Wireless ADSL...
I have an HP Laptop LAN connection will not connect to internet
The wireless modem you are connecting to is protected with a WEP key. You have to get the WEP key or find another wifi hotspot that is not protected.
You can also get a better antenna for your laptop to see if you can pull in another site.
Jul 30, 2009 | Dell Inspiron 1501 Notebook
Internet connection
Have you tryed running a antivirus check? If so it could be your cookie setting in the tools>internet options.
Sep 11, 2008 | Acer Aspire 5100 Notebook
HP Compaq Presario v3000z Notebook Logo
496 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
