Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Very loud humming or whirling noise
Turned on dishwasher and it made a very loud noise. opened the door and it still was making the same noise. had to turn off the fuse at the fuse box to make it stop
It could be the motor starting to seize or the windings in the motor could be going bad either way it should be serviced
Posted on Jan 15, 2009
Why does it make a loud Humming noise?
Something is still in the main wash pump, you hear the motor trying to turn the impeller and it can not
Mar 27, 2016 | Dishwashers
Whirlpool Dishwasher detergent door not operating properly. Main wash door opens immediately after starting dishwasher. No pre wash cycle. Loud humming noise coming from bi-metal switch or wax motor...
if the old dispenser relay was melted or damaged replace control bd the power for the dispenser relay comes from main control and should only be at dispenser when called for in wash cycle ..the control bd is keeping the relay energized too long causing melt down
Sep 10, 2008 | Whirlpool Dishwashers
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
Dishwasher was making a loud hum. I turned it off and started it this morning. Seemed to be working fine, but after about 5 minutes it started making the same loud hum. The first time it seemed to be...
The loud humming noise can be due to the pump sticking if a piece of debris gets trapped in it or an intermittent fault on the pump capacitor or starter relay.
Check out these links below to get tutorials and advice on how to clean the pump or change the capacitor or relay which is cheap and simple job. How to replace Dishwasher pump Bosch Siemens etc Dishwasher Repair Manual Table of Contents http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes.html?start=25
I hope this helps
Feb 05, 2018 | Jenn-Air 24 in. JDB1100AWS Built-in...
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
HDA3400G020WW noise
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
Mar 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Oct 29, 2007 | Dishwashers
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
556 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
