Question about LG Microwave Ovens
LG LRM2060ST trips circuit breaker sometimes
I have an LG LRM2060ST which trips a circuit breaker immediately upon starting about 1 in 4 times it is run. It will do this for small items (coffee cup) or larger ones. It is on a 10A circuit breaker and worked fine in its present position since I bought it 1 year ago until recently. I have moved it to another location with a different breaker and it has the same problem. The microwave's label says it is rated at 14A. Is this a problem with the microwave or was I lucky it worked reliably for a year and the breaker supports too low amperage?
  • gary kohls Jan 13, 2009
    Yes, thanks. Microwave has 'almost' dedicated circuit - range's hood is also on same circuit. 12g wire is present at breaker though I don't know about entire run which worries me a little. House dates to 1988 and is in Illinois. Will check wire gauge at microwave. Assuming that is also 12g, will replace with 20A breaker and will add a surge protector as suggested. Think 10A breaker was installed when I had house upgraded from 150A to 200A service and larger Square D load center installed about 5 years ago.
    Sergeant:
  • 359 Answers
Needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Posted on Jan 13, 2009
I need to know what is the first thing to look at when a mircowave trips a circuit breaker
First off you probably have too many appliances running off the same circuit as your microwave. Try using a different socket. This has happened to me many times at various houses I've lived. For example... My wife uses the hairdryer when I'm warming up some coffee...trips breaker. It basically breaks down to how many circuits your breaker box holds and how powerful it is. Imo Hope this
May 31, 2015 | GE Microwave Ovens
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
I don't know if it is the microwave that blowing the circuit, but that is what my brother said. It blows the circuit sometimes when they use it. Model# MS-104yc 1.5KW or maybe the combination of the air...
Are you referring to tripping the breaker? The microwave runs on 110 volts, and if you are referring to a central HVAC unit, it runs on 220. No way the one could blow the other, unless you are referring to a window unit. If it is tripping the breaker, you could start by replacing the breaker (can buy at Home Depot or Lowes), and if it still continues to trip the breaker, then it is more than likely the capacitor.
Jul 30, 2010 | LG LMV1630 Convection/Microwave Oven
Trips circuit breaker
Make sure it is on a 20 amp circuit with NOTHING else creating a load.
A 15 amp circuit is USUALLY not enough.
If it trips a 20 amp all by itself it probably has a failure that needs servicing.
Dec 08, 2009 | Emerson Microwave Ovens
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
Circuit breaker continually trips immediately when used
check for a shorted hi voltage capacieor ,transistor or shorted multiplier diode
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
402 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
