Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Canon mf4150 picking up toner printing ghost
Picking up toner while printing ghost
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: toner
I had the same problem with this printer. And I think I got the problem solved by removing the all paper from the paper tray, and re-inserting the toner cartridge. I think it is the problem with incorrect error message from Canon's printer. It is problem of paper being fed into the printer mechanism slightly.
Posted on Sep 12, 2008
old marine
  • 2016 Answers
SOURCE: I cannot print on my imageclass mf4150 after installing snow leop
According to their US web site, (type "snow leopard" in the search window in the center of the screen), drivers for OS X 10.6 will not be available until about the end of October.
Posted on Sep 28, 2009
Testimonial: "Thanks! Very helpful"
fosg2000
  • 229 Answers
SOURCE: hi all expert,
if the problem is PRINTING and COPY, the problem will be in the fuser [FM2-8891-000] FUSER (google it).
sometimes they keep dirty sticked to the rollers and when the paper pass trough take from there.
Fosg22000 Rate Me, please
Posted on Mar 17, 2010
SOURCE: Canon mf4150 - Cannot cancel a print job
Hello, I know you wrote this seven months ago, but if you are still having issue, you have to press the "system Monitor" button on the printer. then press ok for print jobs, then the right and left arrors to cancel
It is aggrivating how canon put no shortcut button on the printer to cancel this.
It is under chapter 3 in teh advanced guide you can get at the link below on canon's site.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4150#BrochuresAndManuals
nice day.
Posted on Jan 03, 2011
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Print copy cleaning on canon mf4150
If the toner is not fixed on the paper, and very likely that the fixing film is broken.
in this case it should be replaced fixing unit.
Mar 03, 2015 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf4150 laser 1.5 inches on right side printing smeared tried changing toner running cleaning programme
if the image have smeared or "unbaked" toner leftovers it means that you need to change fixing film.
Hope that helps!
Jun 12, 2011 | Canon imageCLASS® MF4150 All-In-One Laser...
Hi all expert, i got problem with Canon imageCLASS MF4150 All-In-One Laser Printer.the promlem is,print and copy out not clear even i replaced new toner inside..
Mar 17, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Had this for less than a year and now as it prints it sometimes jams and when it does work the printed image is crooked. Seems to be picking up the paper unevenly.
There is probably a crinkled piece of paper stuck in the paper path somewhere causing an alignment issue. Open all the access panels you can and check everywhere for a small piece of paper. Check really good as this issue can be caused by a VERY small piece all folded up.
Aug 08, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
No clear how to adjust the toner gauge on my mf4150.
Click all the link for more information....
Link 1
Link 2
Link 3
Thanks
Good luck
Don't forget to rate the solution
Jan 09, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Have the Basic Guide for new MF4150 Canon copier...need Advanced
My solution is to find better support than you have given...which is nothing! Please do not write again
Thank you, Denise Olsen
Nov 18, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Printer uses too much toner
need to change the quality of the printout. yIf its set to Best quality it will use more toner. Change the print quality to Normal by going to the printing preferences tab.
Sep 26, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
166 people viewed this question
old marine
old marine
