Question about Denon DP-300F Turntable
Denon dp-300f turntable arm does not start in proper position
On automatic the arm drops before reaching the record
djproaudio
  • 515 Answers
SOURCE: Denon DP-47F
You might have a bad cue motor/ass'y. Did you buy this new, or used? Are you the original owner? Did this just start happening? Have you done anything different (moved the unit, cleaned it, etc) to the unit?
If the cue ass'y is bad, then that would require professional servicing.
- TWEAK AV LAB
Posted on Nov 26, 2007
maklean
  • 1665 Answers
SOURCE: belt fell off
There are two main types of phonograph turntable drives still being manufactured today, the belt-drive and direct-drive systems; the names are based upon the type of motor system found in each.
In a belt drive turntable the motor is located under and to the side of the platter and is connected to the platter by an elastomeric belt.
The design of the belt drive turntable allows the use of a less expensive motor than the direct-drive turntable. Also, the elastomeric belt absorbs motor vibrations which would otherwise be picked up by the stylus.
Posted on Jul 18, 2008
  • 120 Answers
SOURCE: Denon dp-35F turntable.
It apears the lead wiring contact arrangement is typically generic. Green over Red and Blue over white. I searched Google by images and found the wiring arrangement in a detailed photograph of a Denon headpiece with cartridge installed.
So always remember to draw a diagram before disassembling something.
Posted on Apr 12, 2009
STYLUSCITY
  • 271 Answers
SOURCE: I have a Denon DP-51F turntable. It was fine the
Hi, it has seized from lack of use. Disassemble and lube it. styluscity@gmail.com
Posted on Sep 13, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Apr 14, 2011
How do I adjust the arm when it won't go to the end of the record?
Usually, the arm won't reach the end of the record when the arm pivot or auto-return mechanism requires lubrication.
May 17, 2015 | Audio Players & Recorders
Brand new Denon DP 300F turns extremely slowly.
The turntable should be under warranty still so contact the makers and they should sort it out. Any tampering with it could void any warranty so don't let any unathoriesed person touch it.
Dec 13, 2014 | Denon DP-300F Turntable
If like what you say the deck is brand new you should contact the service center. They will attend to the matter free of charge. Web address follows:
http://denon.custhelp.com/
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Why does tonearm drop in middle of record instead of start of record
It thinks it's a 45 rpm. There is a trip lever near the edge of a 33rpm record on the turntable that may not be working properly.
Jun 14, 2014 | Denon DP-300F Turntable
How to adjust dp-300f speed
Both the owner's and the service manuals for your turntable are available for download:
http://www.vinylengine.com/library/denon/dp-300f.shtml
You only need to register (free) with them.
May 28, 2014 | Denon DP-300F Turntable
Automatic turntable adjustments
The Service Manual may be downloaded at:
http://www.vinylengine.com/library/onkyo/cp-1055f.shtml
You will have to register (free) before downloading.
Mar 28, 2014 | Audio Players & Recorders
Running VERY slowly
The thing to do is to check the belt first, then look at things like is there a build up of grease dirt anywhere. Clean up the platter make certain no grease or dirt is the works causing it to slow down.
See also that the motor that drives the belt can turn freely and very easy by hand.
Jan 25, 2014 | Denon DP-300F Turntable
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Denon dp-29F won't turn
hit it with a hammer...............
or the other option is to switch off the unit at the wall, then switch it back on again.
Dec 06, 2013 | Denon DP-29F Turntable
Denon DP-300F Turntable Logo
88 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
