Question about Magic Chef Microwave Ovens
Magic chef no:MCO153uw control panel stopped working. Power is ok.
  • 579 Answers
SOURCE: Microwave not heating up
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Jan 03, 2008
ginko
  • 19396 Answers
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Posted on Sep 06, 2008
bestdarngood
  • 3037 Answers
SOURCE: Magic Chef microwave oven (8 years old) heats only
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 12, 2009
  • 457 Answers
SOURCE: magic chef panel does not work. turns on and
the only way the unit that ive encountered with that problem was when bugs aka roaches ran across the circuit board and turned on a range while the customer was on vacation. sorry for being blunt. let me know if this help. you never know this tip might help prevent a fire.
Posted on Feb 27, 2010
heatman101
  • 43501 Answers
SOURCE: Magic Chef microwave oven will not work. No
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 12, 2010
Magic Chef microwave model#mco165ub cant seem to turn up the power level. when I hit the power level button it cycles through -20, 0 and +20 but nothing happens when I hit enter.
Try unplugging the unit for a few minutes. The microprocessor on the control panel may have locked up. Leave it unplugged for at least 15 minutes to see if it will reset.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 16, 2016 | Magic Chef Microwave Ovens
Sep 06, 2008 | Microwave Ovens
We have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
Magic Chef microwave oven will not work. No lights come on, seems to be no power. I checked the outlet - seems OK. Model # MCD990W
heatman101
Nov 11, 2010 | Magic Chef MCD990W Microwave Oven
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCO153UW
You absolutely need the magnetron cooling fan to be working, or the magnetron will be destroyed!
It is part # 3511800100 and you can order it for less than $20 here.
Far less than a magnetron.
Aug 28, 2008 | Microwave Ovens
I need a plate for my over the range microwave oven. model MCO 153 UWF I have been looking for one for several months now and becoming very frustrated.
You can order it online from Magic Chef.
If you'll visit here and select model MCO153UW from the first drop-down menu then select turntable tray from the seconds drop-down menu, you'll find part # 441X335A10.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 28, 2008 | Microwave Ovens
Jan 03, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef mco153ubf
I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem.
Nov 19, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
