Question about Broan-NuTone Dryers
The fan in my vent/heat lamp combo (Broan 164-K) is not working. What do I do?
Is this easy to replace?
SOURCE: replace shower fan motor in a Broan model 678
I need to get the cover off of a BROAN fan and light kit. The two solutions listed did not provide me with sufficient information. Thanks!
Posted on Jul 02, 2009
  • 1114 Answers
SOURCE: Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Posted on Jul 20, 2009
  • 87 Answers
SOURCE: how do you access the light on a broan
Gently pull down, work it down slowly these tend to get dry over time and crack, If you do not see any exposed screws it is the basic pull down type. Not to insult your knowledge but make sure the fan is not on when you do this because the blades will be exposed.
Posted on Oct 09, 2009
Testimonial: "Didn't exactly correct, but I looked further and found 2 screws. "
SOURCE: Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Posted on Aug 01, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Broan Bathroom light fan combo. The fan
Either the plug came out, the receptacle wiring came loose or the bulb is out,,,
http://www.fixya.com/support/r6871896-broan_bathroom_fan_care_cleaning
heatman101
Posted on Nov 17, 2010
How do I replace a fan in a Broan bathroom fan/light combo Model 164-K
I just replace the whole thing if it has attic access. Have an electrician do it if you are not confident of your skill. Having the light work is not very helpful if the unit is shot. Clean and lubricate the fan shaft on your new one once a year and it will last a long time. You may be able to swap out just the fan if unplugs and it is not riveted in but you will have about the same time and money into it as replacement.
Oct 21, 2014 | Broan-NuTone Kitchen Ranges
How do I open the fan to change the light bulb
Hi Roberta - you can view the manual for this fan here.
The lens snaps into position - there are no fasteners that need to be removed, etc. I believe that if you simply squeeze the long sides toward the center, it will release from the fixture.
When replacing the lamps, do not install a lamp greater than 100 watts in the main light socket or a 7 watt C-7 candelabra lamp in the night light socket.
I hope this helps & good luck!
Jun 05, 2012 | Broan-NuTone NuTone - Vent Fan - 9965
I installed the Nutone vent fan light combo with night light and I want to put the fan and light (not night light) on one switch, and not use the night light at all, is this possible? Thank you.
yes there should be 3 wires coming from light one for light one for fan and one for night light just dont hook up night light wire should work fine tape or cape the wire you dont want to use. good luck
Aug 05, 2011 | Broan-NuTone N-8663RP Combination Light...
How do you access the light on a broan fan/heater/light? This is a ceiling unit in a bathroom. It is a vent fan/heater/light combo.
Oct 09, 2009 | Dryers
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
Broan Bathroom Fan Care and Cleaning
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
Dryers Logo
52 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
