Flash drive not working
When i plug in my memorex flash drive into the computer i cannot access my information. i only see a message that there is no flash drive inserted
  • twysted May 11, 2010
    Will your flash drive work in other computers?
    Will other flash drives work in this computer?
    What operating system are you using on your computer?
    Does it actually notify you that you plugged the flash drive in, or does it do nothing when you insert it?
  • 55 Answers
Start my right clicking on My Computer and select manage from the options. Once there click on disk management and find the name of your flash drive or see that it is the correct size. Right click on the name of the thumb drive and select change drive letter and path. Then change the letter to something like Q or a letter not being used. Sometimes that works for me at work.
Posted on Jan 13, 2009
I cannot get my Memorex 64GB USB flash drive to open on my computer. I have windows 7 and when looking at my control panel and under drive status, it says this device cannot start (code 10). What do I...
Trouble shooting steps I would probably take:
1) Power cycle the computer (unplugged), and try it again, when it is COMPLETELY booted.
2) unplug it and plug it into a different port(s).
4) Try it on a different computer (both PC and MAC, as it could be a formatting issue) (if it doesn't work, entertain the reality that I may have lost everything and may have to format the drive and/or buy a new one)
Oct 22, 2013 | Memorex Mega TravelDrive 4 GB USB Hard...
I deleted all the memory in the flash drive, its a 2 gb, but it tells me that theres only 41mgb in it.
Try emptying you trash on the computer that you deleted the information on. Or recycling bin depending on the type of computer. When you "delete" the information from the flash drive, it does not permanently delete it until the "Trash" is emptied.
May 20, 2011 | Memorex Mini TravelDrive - USB flash drive...
Memorex Mini Travel Drive 8 GB USB 2.0 Flash Drive 2 drives are not recognized. Error message asks to reformat. Tried them at various computers including PC and Mac. Thanks. Yee
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Feb 18, 2011 | Memorex Mini TravelDrive - USB flash drive...
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Travel Drive Broke
It depends on your skill level as to if it can be fixed or not. The data is most likely still safely stored on the flash chip inside the drive casing. However, the USB connector has been just ripped off. If you have any experience soldering it would be as simple as getting a replacement usb plug from an electronics store or cutting a cable you have and then soldering the USB connector back to the flash drive inside the casing. This is something than can be done at home or possible by a repair shop that does any type of soldering work(tv, radios, ect) Most computer repair shops will look at you silly if you ask them to solder a thumb drive back to life. I would not expect more than to be able to mount your drive and copy the data. Odds are after you cut it out of the casing it will never go back in correctly.
Good Luck
Aug 21, 2009 | Memorex Electronics - Others
Flash drive is wiped clean
you might have to reformat the flash drive, or if that doesnt work plug it in the computer and go to device manager and see if its damaged and if you can repair through that
Jun 05, 2009 | Memorex Mega TravelDrive 4 GB USB Hard...
Software on flash drive
Stomp is computer backup software.
Nov 26, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Nov 24, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
Detected With Error Code 10 in Device Manager in Windows XP
Have you tried also plugging in the DC usb cable into the traveldrive? I was having problems where my computer wasn't working properly with my drive unless I had it either plugged into a powered usb drive/hub or I had the DC plug in as well.
Jun 04, 2008 | Memorex Ultra Traveldrive - 80GB 80 GB...
Lost the instructions
Ok plug the the device into your usb port. Most usb devices have lights letting you know they are working. After plugging it in if your using Windows goto "My Computer" and look for a new Drive letter like when I plug mine in it says NO_NAME(G:) and then I can access the flashdrive just likes its a regular harddrive. Now you can always already have "My Computer" open so you can see the new drive letter pop up. Don't look for (G:) yours can be different but it might also be named something like TravelDrive(F:) thats just an example. I hope this helps you
May 01, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
Computers & Internet Logo
David Payne
David Payne
