Question about Pioneer DEH-P77MP CD Player
Removal of face plate on head unit
Hi ,
Sometimes my face plate wont remove when i press the button in the top right hand corner? any ideas?
Danny
  • Anonymous Jan 15, 2009
    how would i get this fixed?
    Problem Solver:
  • 3 Answers
Theres a spring loaded device behind face plate used to kick face out either the spring broke or became un seated
Posted on Jan 15, 2009
What does DCP stand for?
[Detachable Control Panel].. Which is your face plate.. I take your having trouble , remove all disk USB mpe attacehed remove face plate you will see a little hole you will need like a paper clip to push the button for about 2 seconds to reset the unit. after resettting attach face plate and try unit.
Feb 25, 2014 | Clarion CX609 Car CD/ MP3 Player
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
Need to remove needle plate
Remove the presser foot and needle. Press the feed-dog drop button on the right-hand end of the machine, so that the feed-dogs drop below the needle plate. Press the back right-hand-side of the needle plate firmly and the front left side should pop up. You can then lift the plate out to clean underneath etc. When replacing, put the hole in the plate over the locating lug at the front-right corner and make sure the right-hand-side of the plate is down first, before pressing the left-hand side down into the grey surround. Be careful not to use excess force if it wont go, otherwise you could break the retaining spring. When done, dont forget to press the feed-dog drop button again and rotate the handwheel once, so that the feed-dogs come back up again.'
Hope that helps
Jan 27, 2012 | Bernina Artista 180
How do you remove the throat plate?
Not sure what you mean by 'throat plate' - do you mean the stitch plate/needle plate ? If-so, the best way is to drop the feed-dogs by pressing the button in the bottom of the handwheel end panel and you then press firmly on the back right-hand corner of the stitch plate - it should then pop-up on the opposite corner and you can remove it. It's held-in by two spring retainers. When replacing it, position it so that the hole in the front right corner of the plate is over the locating lug first and the right-hand side of the plate is in place, then press the left-hand side down into the grey plastic surround in the free-arm.
Hope that helps.
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
customercare@grilltechs.com
Nov 06, 2010 | Tec Patio II Grill
Hi Folks, I have an Aiwa CDC x204 car stereo that seems to be stuck in demo mode. I replaced the battery, so my guess is that this is the default. Upon reading the instructions, it indicates to...
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Sep 15, 2010 | Aiwa CDC-X204 CD Player
How do you reset the DEH P2000?
remove the face, and at the bottom left hand corner of the unit in the dashboard, there is a very small reset pin-head button, press this with a pen, or similar pointed object....that should reset the whole unit
Sep 08, 2009 | Pioneer DEH-P2000 CD Player
Lid switch is bad and needs changing
ready ok lets go...hi always unplug unit first,,facing unit take your hand and grasp corner caps on console,,on right and left corner,of console pull firmly and they will un snap..now remove the 2 phillips head screws..flip console back,,dont remove just flip back..now you will see the lid switch connection it has a gray and brow wire with the green ground,,pull apart,,,now there are 2 brass clips at each corner,,pry up with small screwdrivers from front of clips..pull cabnit towards you,,and leave machine..now on the cabnit theres 2 phillips head screws holding switch,,pull wire over 2 clip at recess in cabnit,,reverse to put together,,
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
GARMIN STREET PILOT 320
To unlock a “frozen unit,
1. power it off
2. Remove the face plate, Gently pry on the face plane. In the center top edge (under the Garmin logo) you’ll see a small notch.
3. on the right side of the unit, press the reset button.
4. replace the face plate
5. Power it back up.
The unit should restart normally.
Mar 21, 2008 | GPS
PIONEER DEH P 5450
turn it off press the time display button located in top left corner then time will display,then pres and hold top right corner button until 12:00 flashes first the 12 will use your channel buttons on right side to scroll up the the time then when you get the correct time set press the clock display button again in top left corner of face plate!merry christmas!!!
Dec 12, 2007 | Car Audio & Video
Pioneer DEH-P77MP CD Player Logo
227 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
