Question about Home Security
I need a manual for a white Rodgers digital comfort set II thermostat
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
szanti
  • 36 Answers
SOURCE: How do I delete the program settings on my
Go to this web site.
Please let me know if this helped.
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6175.pdf
Posted on Dec 06, 2009
liteswink
  • 99 Answers
SOURCE: white-rodgers 1c26-101 owners manual, does anyone
Link: Installation Instruction
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: I need an instrution manual for white rodgers 1F85
Click this link: Manual
Posted on Apr 26, 2010
liteswink
  • 99 Answers
SOURCE: I have a White Rodgers thermostat series 1F78-151
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to cool then and lower the setpoint below room temperature. There may be up to five minute delay before the thermostat clicks in cooling. If the thermostat click this means its not a thermostat you have a problem with your cooling equipment call your installer. If the thermostat did not click the unit should be replaced.
Posted on May 26, 2010
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
Does white Rogers thermostat 1f56n-444 have a reset button
White Rodgers 1F56N-444 User's Manual - ManualAgent
www.manualagent.com > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Aug 04, 2015 | Home Security
I don't want to program the 1f85-275 thermostat, i will adjust when needed
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
Nov 15, 2012 | White Rodgers White-Rodgers 1F85RF-275...
Need a manual for 1F83-0422 thermostat
Operating and installation manuals for several White-Rodgers thermostats are available here: http://www.emersonclimate.com/en-US/products/thermostats/Pages/non_prog_universal_thermostats.aspx . The direct link to the 1F83-0422 operation manual is http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-7136.pdf . Note some of the directions apply to the 1F85-0422, not the 1F83-0422.
I hope this helps.
Oct 31, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I have a White Rodgers digital thermostat .I do not have the manual.I am getting a lo battery message. How do I replace the battery? Does it come off the wall or is there an easy way to open it? I dont...
The outer shell of the thermostat pushes on(clips) to mounting bracket attached to wall.
1. Remove the packing material from the thermostat. Gently
pull the cover straight off the base. Forcing or prying on
the thermostat will cause damage to the unit
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6488.pdf
This is the manual for your unit.
May 24, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
I need operating manuals for White/Rodgers
Please check the model number of the EAC?? Once you have that model number handy you can call this number 18002842925 they send you a softcopy of the manual to your email.
May 09, 2010 | White Rodgers UVP06207 Air Purifier
Home Security Logo
107 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
