Question about LG LS-J0910HL Heat & Cool Mini Split Air Conditioner
Lg neo plasma - LG LS-J0910HL Heat & Cool Mini Split Air Conditioner
3 Suggested Answers
  • 334 Answers
SOURCE: need to find manual to download for LG 2.5 hp neo
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
Posted on Jun 11, 2009
hvac1960
  • 2133 Answers
SOURCE: LG neo plasma air conditioner
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Posted on Jan 04, 2011
INSTRUCTION OF USE OF LG NEO PLASMA AIR CONDITIONER MODEL NO S244HPND6
This is close, but I think it is Country specific, so click on top right and go to LG for your country and put in the model number ONLY. If that doesn't work, contact LG via their contact page.
Manuals & Documents - Support Search Results ' LG UK
www.lg.com > Home > Support > Support Home > Product Support
  1. Cached
Air Conditioning Systems; Residential Air Conditioners; S24AHP ... product, please refer to the Owner's Manual and other documents available for this product.
LG Support Search Results LG
Dec 13, 2016 | LG Heating & Cooling
LG neo plasma error code
It means the lid is open OR it has a short circuit.
Jul 08, 2015 | LG Asmc183vm Neo Plasma Filter
I have an LG neo plasma airconditioner and suddenly it turns off after about two minutes and it comes up with a code C5. Can anyone help please
Comms Error: check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Dec 31, 2014 | LG Heating & Cooling
LG neo plasma air conditioner does not blow cold air
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
I have a lg neo plasma inverter ( s24awn-4) it turns off and comes up with a fault code (26ch) can any 1 help?
Inverter compressor seized. Check compressor windings all equal resistance 1 to 4 Ohms, check to earth 50 MOhm minimum, check run current and Inverter outputs. Helpful?
Dec 26, 2010 | Heating & Cooling
Need to find manual to download for LG 2.5 hp neo plasma wall mounted air conditioner
Jun 11, 2009 | LG Heating & Cooling
Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
Nov 04, 2007 | Computers & Internet
LG LS-J0910HL Heat & Cool Mini Split Air Conditioner Logo
47 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
