Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mr slim outside main unit fuse location on circuit board
Does unit have internal fuses to protect it after power outage and then a surge when it comes back on? If so, where are they?
  • 6 Answers
SOURCE: no heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Posted on Nov 14, 2007
22yooper
  • 828 Answers
SOURCE: Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
Posted on May 22, 2008
  • 958 Answers
SOURCE: Mr. Slim msz-a17na won't turn on after power outtage
after a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Posted on Nov 26, 2008
  • 8 Answers
SOURCE: Mr Slim air unit is blowing out dirt into my room.
Simple matter of cleaning the unit. You have to clean the filters, the coil and around the louver.
Posted on Jun 10, 2009
t1m130
  • 86 Answers
SOURCE: Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Posted on Jul 08, 2009
Power outage happened now power is on and no power to mr, slim .. main unit and wall mount no power ,, fuse box has no tripped fuses
Check the disconnect at the outside unit, little box on the wall. If not, turn power off and remove top to outdoor unit.
Apr 15, 2017 | Heating & Cooling
We had a power outage due to fuses blown on the transitor outside on the pole, caused some appliances to blow out, light bulbs blown right out of their sockets, and my laser56 toystove wont turn back on,...
Blown board. Most in home appliances don't have circuit protectors. That's why the made surge strips. But these won't protect against direct electrical strikes.
Feb 28, 2015 | Cars & Trucks
My hitachi tv 42hxt12u will not turn on and I have a blue light I can see
You have a light indicator suggesting the power from the wall outlet to the TV is functional. The main circuit board is not powering up due to a short circuit from a power surge or internal fuse outage.
Feb 03, 2015 | Hitachi Televison & Video
Where is the fuse locate on the WEP 32801 oven
Ovens don't normally have internal fuse, check your cooker switch on wall near to oven, they usually have a fuse. Otherwise check your fuse board / circuit breaker to see if the fuse or breacker has tripped
Nov 25, 2014 | Whirlpool Kitchen Ranges
Where are internal fuses as have no power when plugged in?
There are several types of internal fuses. sounds like the ones you are looking for are related to providing power to your unit. IF you open up the chassis and follow where the power cord attaches - it will lead you to the power supply board where there are often removable fuses that protect the internals for power surges. Some components actually have these fuses accessible from the outside either integral to where the removable chassis power cord connects or in a fuse holder that unscrews.
Make sure you replace with the same type of fuse!
May 11, 2014 | Yamaha RX-V430 Receiver
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
Had a short power outage now the unit will not run. breaker ok and 234 volts to outside unit but inside unit will not come on. is there a reset or something
Try turning the unit off at thye meter box or the isolator switch out next to the outdoor unit of the air con. Leave off for 15 minutes and then switch back on again. Some Air cons get screwed up with power surges... Leaving off at the mains for a while often resets them. If the air con was running at the time the power went off, it may have damaged one of the electronic boards... Do you get any flashing lights or displays showing what could be an error code ??
Jul 16, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Tv wont power up when it does no picture
The Philips Projection t.v.s have a built in overvolt protection system. The t.v. may have experienced a power surge/outage/issue. Simply unplug the t.v. for about an hour to allow the overvolt issue to drain and reset. My Philips did the same thing about 1 1/2 years ago and we have never had another problem with it since. The repair guy was going to come out and charge us about $400 just to look at it !
Hope this solves the problem. If this does not, unplug the t.v. and carefully remove the back lower cover. There is a small 250 volt .5 amp fast acting fuse near the back of the unit on the circuit board. Use caution This may have been blown during a power spike/outage/surge. This is the first line of defense that gives the t.v. some degree of protection. Most Radio Shacks/Ace Hardware stores carry these small fuses.
Oct 12, 2009 | Philips Televison & Video
tnx 4 using fixya,
Drcool
Nov 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
120 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
