Question about Mtd 22" Yard Machine Push Mower
I have the Yard Machines 8hp snow thrower. I changed the spark plug, tried electric & pull start, but no luck. It was outside in the open for the last 2 years without being used (gas tank was kept empty).
  • naikker Jan 14, 2009
    Machine is 3 yrs old. I tried it again this evening & it started. It was outside for 2 yrs but covered properly.
    Thx for your feedback...
  • 205 Answers
SOURCE: yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Posted on Apr 24, 2009
  • 242 Answers
SOURCE: My Yard Machine 2-Stage Snow Thrower will not
clean out the carb and jets ,add fuel system cleaner and away you go.if no go use easy start
Posted on Dec 24, 2009
heatman101
  • 43501 Answers
SOURCE: My Yard Machines snow blower
The bearing can be a bugger to remove....and it sounds like the bearing may also be bad... so you will want to replace that also...
To get it off make sure that the set screw(s) are backed out with an allen wrench...the set screws will be in a small hole in the lip of the bearing....an allen wrench is a six sides wrench that comes in many sizes... the screws may also be a metric size...
then to remove the bearing you will need to use a gear puller that will grab the bearing equally with thre jaws and the use the shaft for leverage as you turn the screw to pull the bearing off of the shaft...
You will bugger up the shaft if you keep trying without the proper tools and then you will really have a mess on your hands...
heatman101
Posted on Dec 21, 2010
  • 144 Answers
SOURCE: My MTD 10hp auger will
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Posted on Jan 09, 2011
  • 288 Answers
SOURCE: MTD Yard Machines 600-Series Snow
Most likely cause is a failed ignition coil (reason that there is no electricity going to coil is that the coil generates electricity from magnets in rotor). Fairly simple to replace.
Posted on Feb 02, 2011
Need manual
769-06277 Parts Manual, 769-06032 Operator Manual, 769-06052B, Engine Manual. You can find them here,
Yard Machines Snow Thrower 31AS62EE700
Feb 10, 2016 | Mtd Yard Machines 24" Two Stage Snow...
Need to find correct spark plug for Troy-Bilt #42027 Snow Thrower.
Several engines were available, you need to look for the number on your current plug - easiest method.
otherwise, you will need to give the motor manufacturer and nameplate info (Tecumseh SnowKing 8HP?)
Nov 16, 2014 | Garden
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
Yard machine snow blower
be sure to check in blower housing (the round part) that impeller isnt frozen at the bottom
can also take off belt guard (2bolts) and check to be sure belts are on correctly
Dec 18, 2013 | Yard Machines 28" Two-Stage Snowthrower
I just bought a Sears Craftsman snow blower,put gas and oil in it.Itried to pull the starter cord but it will not pull. I then tried the electric starter but it just grinded.Why won t it start?
Sounds like a serious flooding issue, perhaps due to having blower on its side, take out spark plug and place plastic bag over and try pulling over, be careful that it doesn't spark and ignite any fuel expelled out of cylinder.
if that is the case pull over several times blow off plug and try again, fuel might be trapped in muffler so be aware of spray, ignition.
If it doesn't pull over with the plug removed take it back as a valve might be sprung.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Tecumseh 8hp snow blower. Hi started the snowblower this year for the first time with no problems. The oil was changed and the level was fine. I cleared the driveway and after about an hour turned it
not sure i understand you correctly but if it turns over to a spot and stops. it is on the compression stroke. that means the valves are out of adjustment. reset the valve clearances and it should be as good as new. or take the spark plug out and see if when you try to start it it shoots out gas out the exhaust that means you have a bad needle or seat in the carburetor. it will need to have a kit put in it. it is easy to do and cheap.
Sep 01, 2017 | Yard Machines Garden
MTD Yard Machines 600-Series Snow Thrower with gas start, purchased in Nov 2008, will not start. No noise at all (except the motion of the wheel for the recoil starter handle). Gas is fresh (bought it the...
Jan 12, 2011 | Mtd 22" Yard Machine Push Mower
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Mtd 22" Yard Machine Push Mower Logo
262 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
