Question about Samsung Galaxy Tab Tablet PC
Samsung galaxy 2 tablet charger gets hot when charging
5 Suggested Answers
agc93
  • 44 Answers
SOURCE: samsung galaxy tablet is not
Make sure you are using the AC adapter as the Tab cannot charge solely from a USB cable connected to a computer or similar. If it is still not charging, your device's battery or connector has probably failed and will need to be replaced.
Hope this helps, Alistair
Posted on Mar 15, 2011
agc93
  • 44 Answers
SOURCE: How do I know when my Samsung Galaxy Tablet is
The Tab takes quite a long time to charge (not sure why). Note that the Tab cannot charge from a computer USB port (only from the included AC adapter. When the Tab has finished charging, it should put out a notification (open the notification drawer by pulling down on the status bar) saying the battery is fully charged and to unplug the charger. Other than that, you would have to install a third-party app like Smart Battery Monitor (see here) and watch that to see when it is full.
Geekman
  • 32281 Answers
SOURCE: My samsung galaxy tablet is
It appears your Galaxy is faulty and it will still be under warranty. I suggest you take it to the supplier to get it repaired or replaced under warranty.
If you try to repair it yourself, you will most likely void your warranty.
Posted on Jun 25, 2011
reyjoshua07
  • 1157 Answers
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 17, 2011
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
Samsung galaxy tablet 10.1 wont charge show a 1/4 yellow battery then turns off show battery again then shuts off
Either the battery or the charger is done for. If you have family or a friend with the same unit, you can verify your charger and your unit with their equipment.
Good Luck.
Mar 11, 2014 | Samsung Galaxy Tab 2
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
Jan 07, 2014 | Samsung Galaxy Tab 2
My samsung galaxy ce 0168 screen is not working anymore after 2 minutes turned on
Check that the charging port pins are not bent or damaged or corroded use a small needle to clean each individual groove. Replace the charger, suggest Staples or Walmart for the source.
Dec 05, 2013 | Samsung Galaxy Tab Tablet PC
Samsung troubleshooting
it is charger problem or the battery is old -poor-
Nov 29, 2013 | Samsung Galaxy Tab Tablet PC
Samsung galaxy tab 2 10.1 brought today and charging through computer keeps flashing a battery but then disappearing and making a disconnected sound from computer what do i do?
Samsung galaxy is a powerful device which require at least a 2A charger to charge it well. computer can only deliver 0.5A and thus is not enough power to charge your tablet. Connect it to the wall AC charger that come with the tablet and you'll be able to charge it just fine
Sep 16, 2013 | Samsung Galaxy Tab 2
My Galaxy tab 7.7 wont charge, I tried to charge it yesterday when the battery was still 50% charged but now it is down to 15% and my tab won't charged. I am using the original charger, please help!...
my mama said that mayb ur need a new charger cuz Samsung is sending me a new 1 and I think that\'s y. I hav a 7 inch tab 2 n I love it but it stop charging so I don\'t no whats wrong but im getting a new charger so its all good and guppy now :) ill keep u updayted cuz I think its the chargers falt not the tablets!! idk if not then ill just reset my tab and cry my eyes out cuz that sucks big time I meen really who wanna reset there tablet? not mee! but what the hell..mayb a new charger will help the little baby...
Jan 23, 2013 | Samsung Galaxy Tab 7.7 P6800 3G 16GB...
I buy new samsung galaxy tab 7inch on may 2011.Now my problem is my galaxy tab blank/black and when i push botton ON and recharge together but not respond.How to solve my tab problem..Tq
try ti use a different charger it might not be charging properly with your charger, it it charge that way it means its a problem with your charger
Aug 24, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab Tablet PC Logo
494 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
