Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
How to put on front axle assembly on kenmore canister vacuum
SOURCE: kenmore canister switch issue
I have the same problem and took it apart. There are two switches: one on the hose and one that activates the motor - on the right side just inside next to the motor. Took the switch apart (V-`0G-3C25-L) and found it was fried - slightly melted.
Posted on Dec 02, 2008
advacak
  • 125 Answers
SOURCE: kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Posted on Dec 03, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
  • 31 Answers
SOURCE: Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Posted on Feb 16, 2009
  • 382 Answers
SOURCE: How to replace Kenmore canister vacuum filter.
I believe it faces toward the housing
Posted on Dec 19, 2009
My husband accidentally dislodged the belt on my kenmore canister vac. how can we disassemble the head to put the belt back on?
There should be 4-5 screws on the bottom of the brush assembly, remove them and you will see the brush and belt, remove each end of the brush assembly they should lift up and out of the housing,and either replace or reailine the belt on the motor side of the housing.
Aug 25, 2014 | Kenmore Progressive Canister Vac Cleaner...
The nozzle housing has cracked at one end of the front axle assembly. This allows the assembly to slip a little bit, resulting in failure of the lifter. Ds you think it pratical to try to replace the...
contact Parts direct at sears, when you have them on the phone ask them to e-mail you the sheet that shows how that part is assembled,, you can get the part from them, heres the number 1-800-252-1698
May 22, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
I have a kenmore vacuum, Series 116-23613300. four years old. It is emitting a high pitch squeel. I have checked and the hose is not clogged, I have put in a new bag and I have washed the foam filter. ...
If the squeal is coming from the canister portion of the machine, then you most likely have a fairly serious motor/fan problem. There are no moving parts on that machine other than the fan/motor assembly in the canister.
A local service center could confirm that. You can try to get a free quote if they offer such a service. Many may charge a fee even for diagnostic work.
If the noise is coming from the power-head, then there are multiple possibilities ranging from bad brushroller bearings to failing power-head motor.
Apr 04, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Wheel is sticking. I want to remove the wheel to clean the axel. kenmore 116.27514700
Thanks for the clarification. This is actually fairly simple to remove the rear wheel, however as you'll see after this has been removed, there really is no axle attached to this. It just snaps into the main canister housing. It may be that your wheel has broken, and a new wheel may fix your problem.
First here's a link to the parts shematic for your model so you can follow along:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11627514700&productCategoryId=0642000&brandId=0582&brandDescription=KENMORE&modelName=VACUUM-CLEANER&diagramPageId=00001&componentDescription=CANISTER&documentId=P0706048&blt=06
Simply put a flat head screw driver behind the brush, and pry it off. It will easily come right off. You may inspect the wheel, and the wheel housing that it snaps into to make sure there are no obstructions, or pet hair that are slowing the wheel down. Also look at the clips that hold the wheel in place to make sure there's no debris above the clips on the wheel that could slow down the brushes also.
If it all appears to be fine, you may spray some WD40 on the part of the wheel that spins, reinsert it back in the vacuum cleaner and test to see if that fixes it. If it didn't, you might just want to purchase a new wheel assembly.
Here's a link to the rear wheel for Kenmore canisters if you'd like to purchase a new one from our website:
http://www.govacuum.com/kenmore-panasonic-canister-rear-wheel-assembly-panasonic-part-ac99caktzv07-sears-part-4370702.html
Hopefully that helps you. If you have any questions about how to repair this, or other questions that I did not address, simply just add a comment as you did last time, and I'll be more then happy to answer any and all of your follow up questions.
If you found this repair helpful, please be so kind and rate my repair, or leave feedback. This is really appreciated, and one of the reasons that Fixya repair professionals continue to post free repair advice on Fixya.
Chris Jones
GoVacuum.com
Apr 27, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister hose
The part number for the hose is 4370993, you can go to sears.com, put int he part number and order it. You will only get just the hose, you have to take the ends off of the old one and put them on the new hose.
Mar 11, 2008 | Kenmore 22822 Canister Vacuum
Kenmore powermate front axle fell off
It will go on hard. Just angle it until you have it as far as you can go, then use maybe a hammer to knock it the rest of the way.
Jan 10, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
90 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
