Question about Toshiba Computers & Internet
Driver for toshiba mk6465gsx s1 hdd?
Hard disk drive
bronk50
  • 27725 Answers
SOURCE: SMART failure predicted on Hard disk 4 Toshiba: MK2035GSS-(S1)
It means pretty well what it says.
That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual.
Those things predict a hard drive crash, however it could take months for the drive to fail
(or it could be the next minute).
since it's a hardware problem the drive is going to die on you and you will have to replace it.
Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive.
hope this helps
Posted on Oct 09, 2012
  • 205 Answers
SOURCE: Error message at startup !!
SMART stands for Self-Monitoring, Analysis, and Reporting Technology.
If you want lots of details on what it is, and does, take a look at this link:
http://en.wikipedia.org/wiki/Self-Monitoring,_Analysis,_and_Reporting_Technology
It is highly unlikely that you will be able to fix this since it's a hardware problem on the hard drive. The drive may last for years or it may die tomorrow. At a minimum I would back up everything you care about on a regular basis.
If you found this information helpful I would appreciate it if you would rate this solution. I hate to beg, but over half of the solutions I've posted have no feedback. I'm not paid for this I'm just trying to help.
Posted on Dec 31, 2007
SOURCE: HITACHI HARD DRIVE LOCKED
Hello Oldnovii
Yes the BIOS has a hardsrive lock/unlock feature but thats wherethe password needs to be reset. No TOSHIBA did not tell me what the BIOS password was Client had to pay $ 25 to get it removed now they want $ 100 to remove the hard drive lock.
Posted on Apr 13, 2008
Sandy4u
  • 107 Answers
SOURCE: Cannot Detect Hard drive Winxp On Toshiba Satelite L200
Hi ,
u can not detect HDD during installing win-xp coz in u r laptop u have SATA hard drive.
to detct hdd in setup u want to make sata netive mode diseble in COMS setup
Plz check COMS thereis sata netive mode is available ....
if this information is useful for u please rate me......
Posted on Jun 14, 2008
Report
  • 50 Answers
SOURCE: SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
that will be expensive. i just went to microcenter and asked them, they said many hundreds of dollars just to look at it, then like 1600 for the cheapest recovery...
I would
1. stop using it immediately. (after an error like that, you may have only minutes of life left on it)
2. get a 25 dollar external enclosure to put the drive into. If it's IDE make sure you get an IDE enclosure, if SATA, get SATA compat. external enclosure.
3. get another computer, o rgo to a friends house, etc, and try to read your data on their computer after plugging in your hard drive inside the external enclosure.
4. if you can see it, rush like mad to copy the data thats important to your friends computer before the drive is 100% dead.
microcenter and similar stores have external hard drives at $129 dollars for a terabyte. BUY ONE! :-)
Good luck
PS: rumors go around that if you freeze the hard drive in your freezer for an hour, it helps get the data off, dont know if this is in fact true. Once the drive is dead, it's dead. You cant do much about it unless youre willing to part with a lot of money.
Posted on Feb 02, 2009
The harddisk security sata port 0 , how can I open this laptop harddisk because it is locked
If a hard disk is password protected, you must get the password. There is normally no way around it.
However, if the user password has been set, the administrator password on the hard disk can be used to delete it. I am not talking about Windows accounts here, I refer to passwords stored in the firmware of the hard disk.
Jan 18, 2015 | Toshiba MK6465GSX) 640 GB SATA II Hard...
My Toshiba satellite with a mk2555gsx won't boot up no messages, tried recovery discs to no avail.
SMART FAILURE PREDICTED on HARD DISK 2: TOSHIBA MK2565GSX-(S1)
Warning: Immediately back-up your data and replace your hard disk drive.
Press F1 to continue.
What is that problem?? and how to troubleshoot this my computer, the model is neo M1110 noteboke.
Sep 10, 2013 | Toshiba MK2555GSX 250GB SATA/300 5400RPM...
Bad Hard Drive - Toshiba Satellite A665-S5170
I suggest you back up your hard drive right away and have the hardware tested for possible replacement.
Sep 18, 2012 | Toshiba MK6465GSX) 640 GB SATA II Hard...
Hi .. noticing toshiba mk6465gsx hard drive warnings
Back up is always a must. After back up you may want to revert to older time and see if th eproblem persists. If yes then use your recovery CD and recover your system fresh. If the problem still exists then you may have to replace the hard drive. Try the same make and model to save yourself a hstle of driver issues. Once you replace the HDD recover from the provided recovery disk
Feb 22, 2012 | Toshiba Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
My HDD is formatted and the partitions can not be lost. Toshiba sata HDD MK32565GSX (S1)
Do you mean, 'Is it possible these partitions can be lost?' ?
If it is, yes, it's possible IF your HD's sectors are broken and unable to fix.
May 26, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Hello. I have a laptop hp, but i found out that the hdd is toshiba mk6465GSX.. Today i was working in my office and it suddenly crashes and the board didn't see it for booting..in fact the hdd is...
You can try placing it into an external hard drive caddy (your internal plugs into it)
The device will plug in usb 2.0 and recognize as an external drive.
If the drive is unrecognizable, than unfortunately it has physically failed and costs to recovery data are very high.
Always have 2 forms of backup for all data.
May 23, 2011 | Xante Internal IDE Disk Drive Hard Drive
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Cant install windows XP on my Toshiba Tecra S1 laptop.
Where did you get your disk from? It sounds like you may have a bad install disk?
Mar 25, 2009 | Toshiba Tecra S1 Notebook
Computers & Internet Logo
192 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
