Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Burner Problem I have a gas stove top. Ever since it was installed, all burners behave the same way. Instead of having a smooth flame height from high heat to low heat, the burners go from high to low to medium to low as I turn the knobs from high to low. And when they're in a certain range, the flame height is very insensitive to knob control. Anybody have any idea of a possible cause?
  • 3 Answers
Burner main oven not turning up but has a flame
Posted on Jan 03, 2017
  • 183 Answers
It appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Posted on Jul 28, 2007
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Flame on gas stove burner coming out the bottom
The gas comes into the burner thru a fine nozzle at the bottom, then draws in air as it rises and comes out the ring of slots at the top. When it's mixing properly, you get the usual hot blue ring of flame. Looks like either (1) the gas nozzle or the burner is partially blocked (which you checked already), or (2) the gas supply doesn't have enough pressure (could be an obstruction in the feed line or a partly closed tap)
Jan 09, 2014 | Kitchen Ranges
FLAME IS YELLOW INSTEAD BLUE for sunbeam gas range
Yellow usually means more air than gas mixing at the burner. The top of the stove lifts off. There are adjustment screws in front of every burner. Turn the burner on after first locating the screw. Turn the adjustment screw until desired flame is achieved. You want a flame with a yellow tip and the body of the flame blue. Please be very careful not to get burned. Hope this helps.
Jan 20, 2011 | Sunbeam SNS3GMNBB (Gas) Kitchen Range
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
Low flame on gas top burner
Hello Husky!! We can help you get the correct parts to repair this wonderful range. You sin=mply need another burner head to be replaced. We have parts and will make sure we get this out to you asap so you get back up and running soon. How many burner heads would you like to order? Please call or email us asap and we'll get these parts right out to you. We look forward to working with you. 972-859-0929
Feb 01, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Ovens
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
335 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
