Question about Harman Kardon CDR30 2-Disc CD Recorder
Will not finalize the recorded CD
Harman Kardon CD Burner CDR 30 will not finalize the recorded CD
3 Suggested Answers
  • 112 Answers
SOURCE: HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
Posted on Mar 10, 2008
SOURCE: Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Posted on Jan 14, 2009
My hk cdr 30 no reading any digital audio inserted disc. otherwise everything
CD do not just read any types of files, the disc must contain only files compatible with the unit. Check your manual.
Jan 20, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
I have a Harman Kardon cdr 30 that I use to burn my analog Vinyl and cassettes to cd. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
try plugging the HK30 out to R2R in, R2R out to RECV in...RECV (you may need 2 rca "Y" connectors) tape out back HK30 & Cass
the "Y" connector needed is (2) 2 female to 1 male (connect both HK30 & Cass deck)
May 15, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
I have a Harman Kardon CDR 30 that I use to burn my analog Vinyl and cassettes to CD. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
do you remember how your connection was before the RR tape deck? if so connect it back that same exact (when every thing was recording / playing) way as before....(you also need to purchase 4 gold tip "y" connector jacks (2 RCA female to 1 RCA male)) ... in / out jacks you just plug the cassette deck will be shared with the RR tape deck...just note you will not be able to record from cassette to RR tape or vice versa...but you will be record from all other sources...
feel free to rate the help
Mar 27, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
Blank cds don't work
Are you using cds labeled music? These are formatted for cd audio home recorders. Data cds for computers will not work. If in doubt, usually on the packaging it states for home audio.
Oct 27, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Mar 08, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder Logo
57 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
