Question about Maytag MSD2454G Side by Side Refrigerator
Water collecting in bottom of freezer coming from back grill.
Water is freezing in the bottom of my freezer I believe it is coming from the back of the freezer. It was also leaking onto the floor beneath the refridgerator?
  • poshodian Jan 19, 2009
    Water collecting in the bottom of freezer maybe coming from back grill and onto the floor.
  • Anonymous Jan 22, 2009
    I have the same problem. Plus my ice maker does not work :(
  • 3 Answers
To poshodian: There are a few more posts about this problem. Of course, in order to fix it, you have to remove the panel hiding the condenser coils behind the grill and showing the drain hole.
This is what I just posted on one of them:
I’ve had my Maytag 2454 fridge for 8 years. But only this week did the same problem show up as cathy824 and lew223. When I poked a drink stirrer into the top of the drain hole, it was hard as a rock. Not knowing why condensate from the coils was not draining into the hole and tubing that would empty the water into the pan evaporator on the bottom of the fridge, I took everything apart in the back and messed around with the black rubber elbow at the other end of the drain plug. I shouldn’t have bothered, because what I finally did was to pour boiling, boiling hot water over the drain hole to melt the ice and gunk that was frozen solid in the drain tubing. While I was doing that, I poked the stirrer into the hole, washing the gunk down the drain and into the very dry evaporator pan. Keep pouring hot water into the drain hole until you’re satisfied that water can flow freely into the pan.
That solved the problem of condensate water freezing on the bottom of the freezer and running onto the kitchen floor. Thanks to lew223 for the fix! The fridge should be good for another 8 years now.
Posted on Feb 04, 2009
Samsung RS2630sh. Drain line Freezes shut. Water drains to bottom of freezer and freezes there. Cooling coils are not collecting ice. Drain line has been cleaned. Why does it keep freezing shut?
If water still collecting and freezing at freezer bottom then drain line is not cleared and still obstructing the normal flow of water downward.
Aug 22, 2017 | Samsung Refrigerators
N325T water collecting at bottom and back internal wall freezing up
That sounds quite normal as the rear panel is the evaporator skin. Check the drain hole at the bottom isn't blocked
Apr 22, 2012 | Refrigerators
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
In the freezer there is a " grill" in the back wall and I can see a heating element. Water is seeping thru the grill into the bottom of the freezer and is collecting and freezing. Some water also makes it...
Yes there is.
Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½" in diameter this is the drain tube. Try using a turkey baster to flush out the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. After cleaning mix a 50 -50 solution of baking soda and water and run some down the drain tube this should help prevent future clogs. This link should help with acessing the drain.
http://appliancehelponline.com/sxsevapfan.html
Sep 28, 2010 | Maytag MSD2454G Side by Side Refrigerator
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water pooling and freezing in bottom of freezer. I've shut the valve so no water is going to the ice maker but water still collects. I can't figure where the water is coming from. Can you help? Thanks!
Sounds like the drain from the freezer evaporator coil is plugged causing the condensate to overflow and fill the bottom of the freezer then refreeze. Most freezers have a drain line from the evaporator to the bottom of the refrigerator leading to a collection pan to allow evaporation of the condensate. You may be able to access the evap condensate pan by removing the rear panel of the freezer. I can not say for sure without the specific model of the unit in question.
Jun 23, 2009 | LG LFC25760 French Door Refrigerator
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Water pooling underneath bottom drawers
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Water collects and freezes in the bottom of the freezer
Your defrost drain is clogged. Get all the ice out and get to the defrost drain hole at the very rear bottom of the freezer. I use a piece of plastic tubing to run down them and clean them out, but you can use a piece of wire if it doesn't have a sharp end that will damage the tube. You can also remove the rear cover of the fridge and you will see the tube going from the cabinet to the drain pan and clean it from there. Post back if you need further help.
Sep 18, 2007 | Jenn-Air JCD2295HES Side by Side...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Maytag MSD2454G Side by Side Refrigerator Logo
296 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
