Question about Vehicle Parts & Accessories
Truck wont start with viper alarm model 550hf plugged in after taking battery terminal off
Changed the battery now truck wont start it has viper alarm on it model 550hf idk what valet button is or how to reset this alarm so i unplugged the system and the truck started is it gonna affect anything being unplugged
  • 12 Answers
SOURCE: remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Posted on Jan 15, 2009
SOURCE: Alarm System
No it won't reset your alarm system. As part of the bit-writer program, anything you set or change in the alarm menu will remain the same. The only thing that can happen is if you have a DEI 520t back up battery, it may trigger the alarm upon re-connecting. No biggy.
Posted on Feb 28, 2009
  • 82 Answers
SOURCE: All of a sudden my alarm started going off and the only way to turn it off is to start up my truck. Well I tried but it won't start with the remote or the key. My truck battery is fine, I have an opti
There should be a Valet/emergency override switch, you must turn the key to the on position and switch the switch ... the LED should come on solid, try that, if no go .... Call the people who installed the system ... it is malfunctioning .... If you have RF key ... it may be being interfeared with buy the security override system that is required to remote start the car ...
Posted on Apr 30, 2009
  • 33 Answers
SOURCE: took out the viper 550hf and now it will not stay running
You may have to check to see what kind of bypass was used for the remote start, as the bypass is installed between a small gauge white wire that is used for the "code" to signal the computer to allow the car to remain running, via the fuel pump. If the wire was not reconnected, the car will start, but only run for a few seconds.
Posted on May 06, 2009
  • 87 Answers
SOURCE: 1999 jeep grand cherokee will not start because of alarm
Sounds like the brain quit on you, I would uninstall it or completly disconnect it and have it looked at. Make sure you reconnect the factory wires and start over. Also check the ground for the alarm as it will draw current from what ever wire it can and cause all kinds of things.
Posted on Jun 03, 2009
Viper alarm continuosly alarming remote wont stop it and car wont start
Weak vehicle battery. When the voltage drops the alarms microprocessor wigs out. It probably also has a state interrupted circuit which is keeping it from starting.
Jul 14, 2016 | Viper Vehicle Parts & Accessories
Indicator light is stuck on, wont work
have you tried syncing the remote with the system again? i think after the remote loses power for so long it isn't synced any longer
Nov 13, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Nov 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Took out the viper 550hf and now it will not stay running
May 05, 2009 | Vehicle Parts & Accessories
Kill switch is on and I cant deactivate
you to disconect the main harness from the alarm.and take your car to a alarm repair shop.
Mar 10, 2009 | Directed Electronics 479V Remote Gen 2...
Have a viper alarm installed and a factory alarm
try removing the remote fob battery for 10 secs then replacing, i get this problem a lot if the fob battery is low.
Feb 25, 2009 | 2007 Toyota Tacoma
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
